Medion Erazer Engineer MD 34635 . Enable resizable BAR and XMP
4 REPLIES 4
Alex39
Message 1 of 5
Message 1 of 5
I have just bought the prebuilt last week and have seen that the RAM is rated at 3200 yet there is no XMP in BIOS or a way to get it to this speed as it is only at 2933 currently.
Furthermore I also don't know how to enable resizable bar for my Zotac 3060Ti I have looked online and the correct VBIOS is also installed but yet again there is nothing in the BIOS to enable this feature.
Would really appreciate if someone could help me with these.
4 REPLIES 4
andyroo
Message 2 of 5
Message 2 of 5
My RAM is coming in at the correct speed but I'm with you on resizable bar. I can't find a vbios upgrade for this card and have had no luck with the motherboard settings.
Quite frustrating for such a popular card.
Alex39
Message 3 of 5
Message 3 of 5
In the end I just ended up swapping out the motherboard. If you also have the same PC as me the motherboard supplied is garbage. I also changed the CPU cooler and noticed a massive drop in temps.
andyroo
Message 4 of 5
Message 4 of 5
yeah, I've read quite a few on reddit had major slowdowns after enabling it with those motherboards so I gave up on the idea.
I've got 3 years warranty on this so will weigh up whether it's worth invalidating the warranty or not to upgrade.
Thanks for the info
Andy
andyroo
Message 5 of 5
Message 5 of 5
Out of interest, what motherboard did you go for?
4 REPLIES 4
