Medion Erazer Deputy P30: add another SSD and firmware upgrade.
7 REPLIES 7
AndyBiker
Message 1 of 8
Message 1 of 8
Hi,
I've a Medion Erazer Deputy P30 with one SSD M.2 da 1 TB .
Is it possible to upgrade notebook adding another SSD?
If yes, are there only M.2 free slots available or or even SATA ?
 Is there a tutorial or photos of how to remove the back cover and upgrade?
One last thing:
is there a firmware upgrade ? Where can I check?
Thank you!
7 REPLIES 7
EastClintwood
Message 2 of 8
Message 2 of 8
Hello @AndyBiker,
it is not possible to add another SSD in your Notebook.
Further Information can be found on the MEDION Service Page: MEDION Service
Best regards,
EastClintwood
Message 3 of 8
Message 3 of 8
@EastClintwood #
Bist du dir sicher? Sein Board ist ja ein Clevo Board, die meist zumindest 2 Einbauplätze haben. Es muss ja  auch keine SSD (2,5") sein, ein zweiter M.2 SSD Port würde ja auch ausreichen.
Vielleicht kann  @Fishtown  für den Fall der Fälle dazu genauere Infos liefern.
hct3000
Sleeper
Message 4 of 8
Message 4 of 8
I can confirm that this laptop does indeed have 2 x M.2 slots and have added a second to my laptop.
Message 5 of 8
Message 5 of 8
@hct3000
Thank you for the confirmation. But which protocol?
Most possibly the second M.2 Port also is for a PCIe M.2 SSD? Correct?
Cheers, daddle
hct3000
Sleeper
Message 6 of 8
Message 6 of 8
My apologies, i added a Samsung 512GB 970 EVO to mine and it works completely fine.
Message 7 of 8
Message 7 of 8
@hct3000
For complete information, hhis is a NVME- resp. a PCIe M.2 SSD which fits in the second M.2 slot.
hct3000
Sleeper
Message 8 of 8
Message 8 of 8
Yes, the OP asked if he could add a second drive, I'm confirming that this is the case via the second nvme slot.
7 REPLIES 7
