Medion Erazer Deputy P10 SSD / HDD Upgrade ??
7 REPLIES 7
ZoTaG
Message 1 of 8
Message 1 of 8
i see someone said it is not possible to add more to this laptop my laptop only comes with 500gb ssd can i add another one? and if so wich is the biggest size laptop will take.
many thanks
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 4 of 8
Message 4 of 8
Hi @Barandosss ,
here it follows the specs of the HDD Medion sells this model with.
If you HDD has the same connection, then it should be compatible:
Seagate ST1000LM048
* 1 TB
* SATA 6.0 Gb / s (aka "SATA III")
* 5,400 rpm
* 128 MB cache
* Series: Seagate Barracuda
Regards,
Gehringer
7 REPLIES 7
Gehringer
Retired
Message 2 of 8
Message 2 of 8
Hi @ZoTaG and welcome to the Forum!
Can you please confirm the MD and the MSN number of your unit?
If they are MD 61827 and MSN: 30029063, then Medion has models with an additional 1TB HDD installed, so yours should be upgradeable.
Regards,
Gehringer
Barandosss
Message 3 of 8
Message 3 of 8
Hi. Medion Deputy P10 MD61877 MSN30029473
I know, that it has a place for hdd. I have my own hdd 1 TB and I want to install it, but I can't find model/no. of tape (belt? sorry for my poor english) to connect hdd with motherboard. There is no any port, it needs some special connector for sure.
Any suggestions?
Thanks!
Drew
Gehringer
Retired
Message 4 of 8
Message 4 of 8
Hi @Barandosss ,
Seagate ST1000LM048
* 1 TB
* 5,400 rpm
* 128 MB cache
Regards,
Gehringer
Barandosss
Message 5 of 8
Message 5 of 8
Thank You very much!
Drew
Zitzmann
Message 6 of 8
Message 6 of 8
Would it be the same hdd for the 30029468 model?
Message 7 of 8
Message 7 of 8
Hi @Zitzmann and sorry for the late reply.
Absolutely, both machines are based on the same barebone, so you can use the same information we provided a few lines above.
Cheers
MajorToM
renanlack
Message 8 of 8
Message 8 of 8
Hi guys.
I really don't understand why they put a place for HDD or SSD and no SATA conection.
There is a way to put a second SSD in this notebook?
ERAZER DEPUTY P10 MD62132
7 REPLIES 7
