Medion Erazer Crawler E50i - NVIDIA Control Panel Display settings are missing & request latest BIOS
8 ANTWORTEN 8
Imran8
Nachricht 1 von 9
1.509 Aufrufe
Nachricht 1 von 9
1.509 Aufrufe
How can i enable them? I want to boost saturation and contrast so that I can see better in CS2 (Counter-Strike 2)
Thank you!
Also, i need the latest bios for my product. If any mods are here, please send the file.
8 ANTWORTEN 8
RAZZ
Nachricht 2 von 9
1.474 Aufrufe
Nachricht 2 von 9
1.474 Aufrufe
Hi @Imran8
please can you supply the MSN number of your unit (8 digits found on the sticker underneath) and the current BIOS version.
Have you cheeked the Medion Erazer control centre for settings?
Thanks
Imran8
Nachricht 3 von 9
1.453 Aufrufe
Nachricht 3 von 9
1.453 Aufrufe
2408NP50RNCM1KAP2000538 is my serial number 😃 the bios was pre installed
RAZZ
Nachricht 4 von 9
1.451 Aufrufe
Nachricht 4 von 9
1.451 Aufrufe
hi @Imran8
I need the MSN not the SN it is 8 digits long.
thanks
RAZZ
Nachricht 5 von 9
1.450 Aufrufe
Nachricht 5 von 9
1.450 Aufrufe
sorry, and the current BIOS version and any reason you need to update the BIOS?
You don't need to update your computer's BIOS or UEFI unless there is a specific feature or bugfix your system requires, or hardware changes. An error while updating your BIOS can brick your PC, rendering it completely inoperable.
Imran8
Nachricht 6 von 9
1.398 Aufrufe
Nachricht 6 von 9
1.398 Aufrufe
My back plate Haß scratched off. Where can i find it and the BIOS?
Also the Nvidia display Settings are missing.
Imran8
Nachricht 7 von 9
1.337 Aufrufe
Nachricht 7 von 9
1.337 Aufrufe
I want a way to unlock Nvidia display settings.
Nachricht 8 von 9
1.328 Aufrufe
Nachricht 8 von 9
1.328 Aufrufe
Hello @Imran8 and welcome!
To find what you're looking for: Press the Windows key + R
Type msinfo32. Press Enter. There, under "system-sku," you'll find the MSN number: 300xxxxx.
Enter "bios" in the search field. You'll then find: BIOS version/date.
You can find missing drivers here:
https://cdn.medion.com/cdn/download.pl?lang=de&filename=drv_Crawler_E50_Deputy_P60_w11.zip&id=23474&...
should also be found on your computer under drive D
bye Fishtown
Imran8
Nachricht 9 von 9
420 Aufrufe
Nachricht 9 von 9
420 Aufrufe
Hi brother! My system SKU is ML-210008 40089906
Also, although my battery health is 92% and it is plugged in, my battery is now stuck at 0%! It won't go up/charge. I'm trying to talk to my insurance company now. But i would appreciate the new BIOS.
8 ANTWORTEN 8
