Medion Erazer Beast X40
10 REPLIES 10
SaintSloer
Message 1 of 11
Message 1 of 11
Good day,
I am new here and try to push my luck hoping someone could possibly help me out.
I bought the Medion Erazer Beast X40 gaming laptop back in 2023 and at the end of last year the charger decided to stop working.
I have been around many IT shops with none available and checked online, but only found dodgy websites.
I also reached out to the seller and my warranty has expired and they don't sell the chargers separately.
my question is if anyone knows where I could buy this particular adapter.
Below is the adapter.
Many thanks in advance.
10 REPLIES 10
Message 2 of 11
Message 2 of 11
@SaintSloer
Hello,
I couldn't find a PSU for the UK, with your kind of plug. But the one I give you the link is identical in name and concerning  the electrical ratings:
--> https://www.medion.com/medionserviceshop/de/p/netzteil-netzteil-extern-w-o-msn-40071501-40082375
Most probably you have to exchange the plug for the wall socket with a UK compatible model. Or you can use the one from the former former charger which are separate anyway
How you can manage to order it from abroad I do not know. May be your dealer can order it from Medion Germany.
Cheers, daddle
Edit: Typo
Message 3 of 11
Message 3 of 11
Hi @SaintSloer and welcome
available (without power cord for UK , MSN 40071642/ https://www.medion.com/medionserviceshop/de/p/netzkabel-netzkabel-3-pin-180-cm-40071642 )
https://www.medion.com/medionserviceshop/en/p/mains-adapter-mains-adapter-external-w-o-msn-40071501-...
bye Fishtown
Message 4 of 11
Message 4 of 11
@Fishtown
Du kannst es nicht lassen. Ich habe das exakte Netzteil sowie abgebildet in  seinem Post , verlinkt. Ein Chicony.PSU Chicony A20-330P1A C14 P0 1200
Wieso dann noch ein anderes;  dein Verlinktes heisst ein wenig anders, beide genannten haben 330W bei 9,5V.
Den Link für das UK Kabel geschenkt; wenn du das als Ergänzung  gepostet hättest, o.K.
Aber er dürfte ja noch das  Anschlusskabel vom vorherigen Netzteil haben.
Message 5 of 11
Message 5 of 11
Moin @daddle
weil es lieferbar ist.
Sonst noch was ?
Message 6 of 11
Message 6 of 11
@Fishtown
Lass das sich dranhängen wenn die Lösung schon da steht. Das hat mittlerweile System. Bist du so scharf auf " Als Lösung!" angetippt zu werdenß Es wird unerträglich weil so durchsichtig.
Sonst nichts. Das  reicht doch, oder?
Message 7 of 11
Message 7 of 11
Moin @daddle
für dich ist also "die Lösung" ein Teil zu verlinken was dem User seins gleicht aber nicht am Lager/lieferbar ist?
Inwiefern ist ihm damit geholfen?
SaintSloer
Message 8 of 11
Message 8 of 11
Thank you! Sadly it's out of stock.
SaintSloer
Message 9 of 11
Message 9 of 11
Thank you for this, this is in stock. One additional question, how can i know if the plug will fit? As in, will it fit into my laptop? I don't mind for the outlet as I have plenty of adapters!
Message 10 of 11
Message 10 of 11
@Fishtown
Es gleicht dem nicht nur sondern es ist dem Namen und der Beschreibung nach identisch.  In diesem von mir gegebenen Link steht nicht  "Nicht lieferbar", sondern es steht da "Wird bestellt".
10 REPLIES 10
