Medion Erazer Bandit P10 MD35137
4 ANTWOORDEN 4
Arnoud
Bericht 1 van 5
2.470 Weergaven
Bericht 1 van 5
2.470 Weergaven
Did anyone figure out how to remove the plastic top cover of the Medion Erazer Bandit P10 MD35137 (MSN 10024193)?
There is a perforation prepared for an extra cooling fan, but you would need to acces the top in order to fasten the screws for the fan. On the motherboeard a for pin FAN2 connection is also provided.
4 ANTWOORDEN 4
Bericht 2 van 5
2.463 Weergaven
Bericht 2 van 5
2.463 Weergaven
Hi @Arnoud and welcome
Do you mean like here with the picture (Zusatz).
https://community.medion.com/t5/ERAZER-Gaming/Teil-4-Review-MEDION-Erazer-X87029-MD34457-Erazer-Insi...
 @Fox10  may be able to help you.
Or without removing the top cover. with four plug dowels from below.
there are also accessories for the body series in motor vehicles
bye Fishtown
Arnoud
Bericht 3 van 5
2.453 Weergaven
Bericht 3 van 5
2.453 Weergaven
Hi Fishtown,
Where did you find these plug dowels, and are you sure they are the rights size?
Bericht 4 van 5
2.440 Weergaven
Bericht 4 van 5
2.440 Weergaven
Hi @Arnoud
what diameter do you need?
https://www.conrad.de/de/p/tru-components-tc-srr-380k203-spreizniete-loch-3-mm-schwarz-1-st-1593338....
you put these first through the holes in the fan and then through the holes in the chassis. now you push the center pin in.
bye Fishtown
https://www.google.com/search?client=firefox-b-d&channel=trow5&sxsrf=AOaemvKm33OyjYcuo0RDuQOtv5CkGJ0...
Arnoud
Bericht 5 van 5
2.413 Weergaven
Bericht 5 van 5
2.413 Weergaven
Ik heb wat beters gevonden, Noctua NA-SAV4 Anti-Vibration Mounts.
Eerst nog even aankijken of de computer case een extra fan nodig heeft, tot nu toe zijn de temperaturen erg netjes. En dan nog bedenken wat beter is, naar binnen of naar buiten blazen.
https://www.alternate.nl/Noctua/NA-SAV4-Anti-Vibration-Mounts-bevestiging/html/product/1356065
4 ANTWOORDEN 4
