Medion ERAZER X62 MD35081 rebooting issue
13 REPLIES 13
danben83
Message 1 of 14
Message 1 of 14
Hello,
Seems like I have the same issue as many others when it comes to the MSI Z490 GAMING EDGE WIFI in combination with a RTX graphic card (mine is a RTX3080) and the intel Core i9 11900kf cpu.
I have Windows 11 installed right now.
I get random reboots. Sometimes it takes 5 minutes and sometimes several hours before the screen goes black and the computer reboots.
The memory dump tells me it is the classic NVIDIA nvlddmkm.sys driver that crashes.
My system unfortunately have the OEM version of the Medion BIOS and the version is 205 so i'm not able to update the BIOS with the newest MSI release.
18th of october MSI released a new BIOS with some sort of better support for Windows 11.
According to this thread some people seems to have got a new OEM-BIOS and it looks like that BIOS version is based on the october update from MSI:
https://community.medion.com/t5/ERAZER-Gaming/Frust-beim-ERAZER-Hunter-X20-MD-34685/td-p/124296/page...
I'm not sure how they got the new update, but I can't find anything newer than version 205 for my computer model (MD35081).
Is it possible that you can send me this BIOS update @Andi so I can test it on my computer to?
It looks like they have almost the same components in their computers so I guess it should work.
Another thread similar to this thread is this one. But I don't think this thread has the final answer to the rebooting problem:
https://community.medion.com/t5/ERAZER-Gaming/Medion-ERAZER-HUNTER-X62-MD35081-randomly-reboots/m-p/...
My MSN number is: 10024085
//Edited
After reading some more in the post above (I'm not good at German so I rely on Google translate) it looks like the update people are testing is the MSI-BIOS 7C79v1A  and not some new OEM version from Medion. It could be good news if that is true.
I guess I can change the Flash.bat and make afuwinx64 point to the MSI-BIOS but i guess it is better to wait for an answer from @Andi
I don't want to spoil my warranty in some way 🙂
People have been successful updating the BIOS in this thread also;
https://community.medion.com/t5/ERAZER-Gaming/Medion-Erazer-Hunter-X20/td-p/112156/page/16
Best regards
13 REPLIES 13
Slikkie
Message 11 of 14
Message 11 of 14
Hiya NonkelCharel, it did not solve the issue for me I’m afraid although the nature of the issue has changed.
Instead of reboot, the game I’m playing just shuts down. I’m yet to experiment with the newer versions of the bios.
hope it works for you tho,
cheers slikkie
Message 12 of 14
Message 12 of 14
Hello @NonkelCharel and welcome to the community.
Please let me know the eight-digit article number of your PC.
Greetings - Andi
NonkelCharel
Message 13 of 14
Message 13 of 14
Hi @Andi
Thanks for your reply, my MSN is 10024428
Greetings,
NC
Terar
Visitor
Message 14 of 14
Message 14 of 14
Hi
i can`t update bios
my motherboard MSI Z490 GAMING EDGE WIFI  bios is stuck at E7C79W0X.205  from 11.06.2021
my MSN 10024076
i5 10400f and 3070
can  someone help me get newer bios version
@Andi
13 REPLIES 13
