17.07.2022 09:50
17.07.2022 09:50
Hello!
I have a Medion ERAZER ENGINEER X10 with i711700f, RTX2080 Super and 16gb of RAM.
I was considering upgrading to 32gb and used Speccy to see what speed RAM I have atm. It says it runs at 1462Mhz(!). Why so low? Can I change this in BIOS?
Also, what Mhz RAM can I buy? The Mother Board is stated as a MEDION B460H6-EM (U3E1) and I have trouble finding info about it.
Any help would be greatly appreciated.
17.07.2022 10:17
17.07.2022 10:17
Hello @JulleBulle and welcome
engineer x10 there are many. it's easier please state the MSN number.
bye Fishtown
17.07.2022 11:11
17.07.2022 11:23
17.07.2022 11:30
17.07.2022 11:30
Hi @JulleBulle
look under the device if it is not on the back.
or on the outer carton
bye Fishtown
17.07.2022 11:40
17.07.2022 11:40
Hi @JulleBulle
10023887 is right
information about the main memory/RAM
2x 8 GB DDR4-SDRAM (PC4-25600 / 3200 MHz) Dual Channel Memory (2/2 Slots covered; 32 GB max.)
information on the support RAM / B460H6-EM
Memory Support
bye Fishtown
17.07.2022 12:18
17.07.2022 12:18
Do I understand it correctly that the motherboard doesn't fully support the RAM installed? Max supported ram is 2666Mhz, not 3200.
17.07.2022 19:37
17.07.2022 19:37
Hi @JulleBulle
that is correct, see also here:
(Wieviel Arbeitsspeicher (RAM) kann maximal eingebaut werden?)
bye Fishtown
11.11.2024 10:20
11.11.2024 10:20
Have experienced any freezes and BSODs with your Medion Erazer PC?
I have the exact same PC as you, and my PC started to freeze when playing games or when doing other tasks where the RAM is in use.
I wrote a topic a few days ago about my problem;
