Medion ERAZER ENGINEER X10 RAM speed
8 REPLIES 8
JulleBulle
Message 1 of 9
Message 1 of 9
Hello!
I have a Medion ERAZER ENGINEER X10 with i711700f, RTX2080 Super and 16gb of RAM.
I was considering upgrading to 32gb and used Speccy to see what speed RAM I have atm. It says it runs at 1462Mhz(!). Why so low? Can I change this in BIOS?
Also, what Mhz RAM can I buy? The Mother Board is stated as a MEDION B460H6-EM (U3E1) and I have trouble finding info about it.
Any help would be greatly appreciated.
8 REPLIES 8
Message 2 of 9
Message 2 of 9
Hello @JulleBulle  and welcome
engineer x10 there are many. it's easier please state the MSN number.
bye Fishtown
JulleBulle
Message 3 of 9
Message 3 of 9
Hi!
Where do I find this number?
JulleBulle
Message 4 of 9
Message 4 of 9
Is it this: MD34944?
Or this: ML-110000 10023887?
Message 5 of 9
Message 5 of 9
Hi @JulleBulle
look under the device if it is not on the back.
or on the outer carton
bye Fishtown
Message 6 of 9
Message 6 of 9
Hi @JulleBulle
10023887 is right
information about the main memory/RAM
2x 8 GB DDR4-SDRAM (PC4-25600 / 3200 MHz) Dual Channel Memory (2/2 Slots covered; 32 GB max.)
information on the support RAM / B460H6-EM
Memory Support
  • Supports max. DDR4 2666 MHz Memory
  • 2x DDR4 memory slots supporting up 32GB
  • Supports Dual-Channel mode
bye Fishtown
JulleBulle
Message 7 of 9
Message 7 of 9
Do I understand it correctly that the motherboard doesn't fully support the RAM installed? Max supported ram is 2666Mhz, not 3200.
Message 8 of 9
Message 8 of 9
Hi @JulleBulle
that is correct, see also here:
https://community.medion.com/t5/FAQs/FAQ-Spezifikationen-Mainboard-quot-ECS-B460H6-EM-quot/ta-p/9715...
(Wieviel Arbeitsspeicher (RAM) kann maximal eingebaut werden?)
bye Fishtown
Fraydoc
Message 9 of 9
Message 9 of 9
@JulleBulle
Have experienced any freezes and BSODs with your Medion Erazer PC?
I have the exact same PC as you, and my PC started to freeze when playing games or when doing other tasks where the RAM is in use.
I wrote a topic a few days ago about my problem;
https://community.medion.com/t5/ERAZER-Gaming/Problem-with-Medion-Erazer-Engineer-x10-MD34944-freezi...
8 REPLIES 8
