Medion Crawler E10 - New screen needed & need help identifying the code for the product
4 REPLIES 4
Hummingbird74
Message 1 of 5
Message 1 of 5
I bought a Medion Crawler E10 Core i5-10300H Geforce GTX Gaming laptop for my son last year.  My son dropped his laptop and the screen needs replacing. I've been to 2 computer repair shops and they said they have tried to locate the screen with their suppliers and no-one can work out which screen is needed.  One of them called customer support at Medion and apparently the code for the product they gave wasn't enough to locate one.  I'm a bit of an amateur with computers and am feeling a bit lost if 2 computer specialists can't even locate a screen - but it was so expensive I can't afford to just buy him a new computer.  I'm hopeful that someone monitoring this forum can help me.  Thank you in advance for any support you provide.
4 REPLIES 4
mats749
Message 2 of 5
Message 2 of 5
Hi @Hummingbird74
Welcome to the community.
Please can you confirm the MSN number of the E10 ?
Thanks
Mats749
Hummingbird74
Message 3 of 5
Message 3 of 5
Hi Mats749, thank you for replying.  The MSN is 30033530
mats749
Message 4 of 5
Message 4 of 5
Thanks @Hummingbird74
The model number of the display is LP156WFC-SPD1
I hope this helps 🙂
Thanks
Mats749
Hummingbird74
Message 5 of 5
Message 5 of 5
Thank you so much.  I'm not sure yet if it helps - I'll contact my computer support person and check.  Is it ok if I come back if they say they need more information?
4 REPLIES 4
