MEDION - P6661 15.6" I want upgrade m.2 drive to 256 GB FROM 120 GB
3 REPLIES 3
sivaji
Message 1 of 4
Message 1 of 4
Please advice which type SSD to buy ,will it support NVMe and which B&M Key or M key .what is maximum read speeds and write speed it can acheive?I was looking at SSD with  3,500 MB/s and write speeds of up to 2,700 MB/s.
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @sivaji ,
unfortunately we can't recommend any third-party products but I can provide you the full specs of your SSD so you can ask the seller if the product is a suitable replacement for this one:
Phison PS3111-S11
* Form Factor: M.2 2280-D5-B-M
* Capacity: 128 GB
* SATA Interface: SATA Revision 3.2
* SATA 1.5Gbps, 3Gbps, and 6Gbps interface
Flash Interface
* Flash type: TLC
* 1pcs to 4pcs of TSOP/BGA flash
Performance
* Read: up to 550 MB/s
* Write: up to 450 MB/s
Power Consumption:
* Active mode: TBD
* Idle mode: TBD
Temperature Range:
* Operation: 0*C ~ 70*C
* Storage: -40*C ~ 85*C
Regards,
Gehringer
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @sivaji and welcome to the FORUM!
Can you please let us know the MSN number of your product?
It is an 8-digits number that you can find printed on a label underneath it. It usually starts by 100, 300 or 500.
Regards,
Gehringer
sivaji
Message 3 of 4
Message 3 of 4
hi please find the MSN number 30021743
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @sivaji ,
Phison PS3111-S11
* Capacity: 128 GB
Flash Interface
* Flash type: TLC
Performance
Power Consumption:
* Active mode: TBD
* Idle mode: TBD
Temperature Range:
Regards,
Gehringer
3 REPLIES 3
