MEDION ERAZER RECON P10 MD35116
12 RÉPONSES 12
Ricoooooo
Message 1 sur 13
6 529 Visites
Message 1 sur 13
6 529 Visites
Hi, I was wondering if anyone can give me a link or pdf file with info on the motherboard that comes with the MD35116? Thanks in advance.
12 RÉPONSES 12
P1a5ma-
Message 2 sur 13
4 910 Visites
Message 2 sur 13
4 910 Visites
Hi Ricoooooo,
Do you have the MSN number of that computer?
Thanks
Ricoooooo
Message 3 sur 13
4 903 Visites
Message 3 sur 13
4 903 Visites
Hello,
Thanks for your reply!
The MSN number is: 10024177
P1a5ma
Message 4 sur 13
4 892 Visites
Message 4 sur 13
4 892 Visites
The P20 comes with the ECS B560H6-EM2 V1.1
What information are you looking for and I might be able to help.
Thanks
Ricoooooo
Message 5 sur 13
4 887 Visites
Message 5 sur 13
4 887 Visites
Thank you.
if want to know which m.2 sata slots I have because I tested slot m.2_2 with m.2 nvme ssd but that was not working.
Thank you.
P1a5ma
Message 6 sur 13
4 883 Visites
Message 6 sur 13
4 883 Visites
Hi Ricoooooo,
This board has 2 slots,
1 x M.2_2 SATA  support for only 2260 and 2280
1x M.2 for PCIE x4 NVME SSD, optane and SATA support 2242, 2260 and 2280.
I hope this helps!
Thanks
Ricoooooo
Message 7 sur 13
4 879 Visites
Message 7 sur 13
4 879 Visites
So what can I do to use the two m.2 slots together with nvme ssd?
P1a5ma
Message 8 sur 13
4 874 Visites
Message 8 sur 13
4 874 Visites
Which M.2 do you have?
If its an NVME/PCIE it will not work in the M.2_2 slot. you'll need to use a compatible drive for the slots you wish to use.
Thanks!
Ricoooooo
Message 9 sur 13
4 870 Visites
Message 9 sur 13
4 870 Visites
I have the default m2 ssd that comes with the machine from the factory. I don’t know which this is. Could you let me know? See picture.
Message 10 sur 13
4 862 Visites
Message 10 sur 13
4 862 Visites
@Ricoooooo
Your MSN 10024177 says following Medions Database entries your Mainboard of the Recon E10 is a B460H6-EM. And if the MSN is given correctly, it is not a Recon P20.
This Board has two slots for M.2 SSDs one for the PCIe protocol, and one M.2 Slot for a M.2 SSD with SATA protocol.
As far as the database entries are trustworthy, your first M.2 SSD  the PC came equipped with a  512 GB Phison PS3111-S11 B27 SSD which utilizes the SATA protocol, So the free M.2 Slot should be able to recognize a PCIe M.2 SSD. This one is the vertically slot situated next and below the RAM slots.
Look here: -> https://community.medion.com/t5/FAQs/FAQ-Spezifikationen-Mainboard-quot-ECS-B460H6-EM-quot/ta-p/9715...
Is this the layout of your board?
But I wonder, because the Mod @P1a5ma says your PC contains " P20 comes with the ECS B560H6-EM2 V1.1"  ?
Then the entry on the service page must be wrong, in the intern campus-database the MSN 10024177 is not listed yet. So there must exist a separate database for the  service pages entries.
First, your MSN says you got a Recon E10, second it is equipped with a ECS B460H6-EM Board
But independant from this  mix up, so far both boards in question have a M2 SATA and a  M.2 PCIe Slot.
Because the Service Page  says your PC MSN 10024177 comes equipped with a SATA M.2, (if this entry is correct at least!), the second empty slot should be able to recognize a M2 with PCIe Interface.
On the B 460 board it is the horizontally slot underneath the graphic card.
The ECS B560H6-EM2 V1.1:
B560H6-EM V1.1B560H6-EM V1.1
Look here: ->  https://community.medion.com/t5/FAQs/FAQs-zum-Mainboard-ECS-B560H6-EM2-V-1-1/ta-p/132487
But I do not know which M.2 Slot is named M.2_2  or M.2_1 .
Seeing your PC came equipped with a SATA M.2, (this is I guess the vertically slot aside the RAM slots), the other free slot underneath the graphic card should be the PCIe M.2 slot.
Did you find the PCIe M.2 on the page Advanced (or Chipset) in UEFI, in  SATA configuration, or in the catagory Intel Rapid Storage Technology?
Not all non bootable disks are listed in UEFI on the page " Boot "
Did you check within the disk managment? May be the new M.2 ssd first must be initialized.
Cheers, daddle
12 RÉPONSES 12
