M.2 SSD upgrade compatibility?
1 REPLY 1
pepsiguzzeler
Message 1 of 2
Message 1 of 2
Hi there, I have a Medion P6661 erazer laptop, MSN300217373, I'm looking to upgrade the Ram and SSD, for the SSD, I'm finding conflicting information about compatibility, the slot is M key compatible, but others have reported NVME PCI SSDs do not work on this model, is this true, and what is the fastest M.2 SSD I can install onto this laptop? The current installed SSD is a SATA B + M compatible SSD.
Lastly, the battery is pretty poor now, are there any large capacity batteries available for this laptop? The current installed SSD is a SATA B + M compatible SSD.
1 REPLY 1
Message 2 of 2
Message 2 of 2
Hi @pepsiguzzeler ,
on your MEDION AKOYA P6661 Skylake model we use DDR3 dual channel SO-DIMM modules (PC3-12800) which run on a max of 1600 MHz with 1,35V. The max evaluated RAM storage capacity of each slot is 8 GB.
The unit has one SATA port (up to 6 Gb/s, max 2 TB capacity) and one 1 NGFF M.2 (2280) port up to 6Gb/s and a evaluated max.capacity og 512 GB.
Does this help?
1 REPLY 1
