le 20.06.2021 20:14
le 20.06.2021 20:14
Hi All, hope you can help. Erazer P6705 with Nvidia GeForce GTX 1050 Ti graphics. I have lost the option to add multiple displays. Just bought the machine used. The option was there when I first bought it. Any suggestions. I have tried reinstalling the driver for the graphics card, from Nvidia website.
May thanks,
Malcolm.
le 20.06.2021 21:21
le 20.06.2021 21:21
Hello @malgpz900 and welcome
What are you looking for! the graphics driver?
http://www1.medion.de/downloads/index.pl?op=detail&id=18557&type=treiber&lang=uk
bye Fishtown
le 21.06.2021 08:15
le 21.06.2021 16:42
21.06.2021 19:40 - modifié 21.06.2021 19:46
Hello @malgpz900
unfortunately I do not understand what you mean by "the option" has been lost! you have connections for:
1x HDMI 1.4 Out
2x mini DP 1.2 / 1.3
15.2.Connecting an External Monitor
The Notebook has two mini diplay ports as well as an HDMI port for an external monitor. `Shut down your Notebook correctly.`Plug the external monitor’s signal cable (not included) into a mini display port on the Notebook. Alternatively, you can use the digital HDMI connection (High Definition Multimedia Interface) to transmit picture and sound signals.`Connect the external monitor to the mains and switch it on.`Now switch your Notebook on.
switch with FN + F7
Display Switches: the screen display between LCD, external display and duplicate display.
bye Fishtown
Edit/ useful: N857EK1= N850EK1_SM
le 21.06.2021 20:44
le 21.06.2021 20:44
@Fishtown yeah, tried both those options as detailed in the manual, neither works. I only have an HDMI cable to try the external monitor. I'm reluctant to buy another mini DP cable if its a hardware issue. I've got a call out to Medion Support to see if its still covered by warranty. The fn/ f7 shows the different display options, but monitor is saying no HDMI signal. Thanks for your help though.
Malcolm.
le 21.06.2021 20:56
le 21.06.2021 20:56
Hi @malgpz900
Often times the HDMI cable is faulty try another one.
or if you don't have another.
Test the monitor with HDMI cable on the TV set. so you can test monitor and cable
bye Fishtown
le 21.06.2021 21:26
le 21.06.2021 21:26
Yeah, tried different HDMI cables and also plugged monitor with HDMI cable into another laptop and it worked.
