Latest BIOS for Erazor Specialist P10
18 REPLIES 18
FlapjackUK
Message 1 of 19
Message 1 of 19
Hi All,
I would like to install the very latest BIOS for my Erazor Specialist P10 but I cannot find anything online for it, would anyone be kind to point me in the right direction?
MSN: 30034002
MD62447 UK
Regards FlapjackUK
Tags (2)
18 REPLIES 18
Message 11 of 19
Message 11 of 19
Hello @FlapjackUK
I have not answered you until now because I have no further information for you. can not tell you if there is a newer bios or you have the latest.
I'm just a user too.
let's hope that @EastClintwood  can tell you something else.
bye Fishtown
FlapjackUK
Message 12 of 19
Message 12 of 19
@Fishtown thanks for replying, I thought you were a supermod 😂 Sorry!
FlapjackUK
Message 13 of 19
Message 13 of 19
Can anyone tell me how I can update the BIOS using Windows update? A new BIOS update doesn't show in windows update. This is crazy that it's so hard to find the latest BIOS update which I have been informed by MEDION customer service is 1.07.04RME1.
Message 14 of 19
Message 14 of 19
Hello @FlapjackUK
try the following:
key Win + x (open selection menu )
key g (opens device manager)
double click on "firmware"
right click on "system firmware"
there on "update driver", click
click on "search for drivers automatically"
click "check for updated drivers on windows update",
(if there is one then there)
bye Fishtown
FlapjackUK
Message 15 of 19
Message 15 of 19
Hi @Fishtown thanks for the reply. I have already done this process but nothing comes up on windows update, it just says "up to date".
Message 16 of 19
Message 16 of 19
Hi @FlapjackUK
then your computer is probably up to date.
However, if the Medion service states that there is a newer version, they may make that available to you as well.
or windows update also has the new version, but has not yet put it online.
is there a problem with the computer or why the bios update?
bye Fistown
FlapjackUK
Message 17 of 19
Message 17 of 19
Hi @Fishtown no, no problems at all but I like to have the newest version of everything. Thanks for helping, I will contact MEDION customer service again to see if they can send me the latest BIOS update.
Message 18 of 19
Message 18 of 19
Hi @FlapjackUK ,
thanks for your patience, but @Fishtown is right, by the facts, that updates are generally provided by the Windows update functionality of your system (do not forget to even hunt for optinal updates)
Had a chat with the tech folks and have the version 1.07.04RME1 available here
The thing with the update is, that i have no logfile in hand, which means, that I can´t tell you about the modifications and as we all know updating a successfully running system might lead to "strange behaviour", so you have to be aware, that for any errors, which are caused by the execution of this update, MEDION campany doesn´ t accept any responsibility for damage or lost of data.
You agree with that fact by executing the update.
Cheers
FlapjackUK
Message 19 of 19
Message 19 of 19
@Major_ToM Many thanks for your help, really appreciate it 🙏
18 REPLIES 18
