I want to upgrade my crawler e25
6 REPLIES 6
senne
Message 1 of 7
Message 1 of 7
How could I upgrade te ssd in my laptop? I dont really know anything about PCIe ssd
Tags (3)
1 ACCEPTED SOLUTION
Message 4 of 7
Message 4 of 7
@senne
I am sorry, this I can not answer for sure.
The nearest I come is with  this Manual --> https://www.manualslib.com/download/2734538/Clevo-Nh55edq.html
I guess it shows  how to remove the bottom of the laptop.Than you can see if there is an empty space for a second M.2 SSD.
6 REPLIES 6
Message 2 of 7
Message 2 of 7
@senne
Hi Senne, you should specify what you want to do. Upgrading can be a SSD with bigger capacity, or to put in a second SSD (if that is possible) .
Second you should state the MSN number; you can find it on a sticker underneath the Laptop, or on the sales box.
Cheers, daddle
senne
Message 3 of 7
Message 3 of 7
msn 30032487
I would preffer an extra ssd, but replacing the existing one is fine if thats not possible.
Message 4 of 7
Message 4 of 7
@senne
senne
Message 5 of 7
Message 5 of 7
Thx
Message 6 of 7
Message 6 of 7
Hello @senne
you have a bareone clevo NH55EJQ.
A suitable service manual can be found here: https://my.hidrive.com/share/yze8mg-wf8#$/CLEVO%20Service%20Manual%20Books/N_Series/NH/NHxxExx/NHxxE...
Since your computer already has an M.2 2280 PCIe Gen3 x4 SSD installed, you can install a second one, see page Specifications 1 - 3
bye Fishtown
GI_in_OZ
Message 7 of 7
Message 7 of 7
Hi, you can change the M.2 drive to whatever you like, populate the second M.2 socket., and install any SSD you like in the 2.5" SATA bay.
Currently, I have replaced the original m.2 drive with a 1TB drive (Cloned from the original m.2 drive.) In the second slot, I have a 2TB m.2 drive installed and a QVO 4TB SSD in the SATA bay.
6 REPLIES 6
