le 04.08.2020 20:23
le 04.08.2020 20:23
Hi all,
Can anyone shed any light on why its soooo difficult to take the back off the X17801?!!
I have taken 12 screws out, i cant find any more and I've looked for over an hour now and it feels as though its stocking in the middle, I'mscared i will damage it if I forced it open.
I just cant see any other screws holding it in....
le 04.08.2020 21:08
le 04.08.2020 21:08
On my laptop (medion erazer but different model though) I had to remove the keyboard too in order to gain access to another 4 screws.
le 04.08.2020 22:02
le 04.08.2020 22:02
thanks, and how do you do that?
i can see that next to 2 of the screw holes there is an icon that looks like a keyboard, almost as though you need to push it forward but wont that break the keyboard?
05.08.2020 15:50 - modifié 05.08.2020 15:50
First check around keyboard for holder marks like the one in pic (above ESC)
See on this video how the keyboard can be removed. https://www.youtube.com/watch?v=joLnSK9N-uU
The lack of marks means different holding system and in that case ignore everything I said.
le 09.08.2020 18:20
le 09.08.2020 18:20
Many Thanks,
That worked, I had to remove the keyboard panel as you showed which revealed 3 more screws, once removed the back panel come of quite easily!
