Erazer P10 PC fans too noisy
2 REPLIES 2
Filce123
Message 1 of 3
Message 1 of 3
As the title says, i have an Erazer Medion P10 PC gaming and the fans are too noisy, i have tried apps such FanControl or SpeedFan and none of them detect the external fans, they detect gpu fans tough. The Motherboard model is the B560H6-EM and i checked if the fans were attached to the mother board and they were, i went into the BIOS and looked for fan control options, there were none. I tried looking for a software for my motherboard and there were none.
I'm out of options, any ideas how to control those fans?
1 ACCEPTED SOLUTION
Filce123
Message 3 of 3
Message 3 of 3
I unplugged the fans and the noise barely changed, i looked further and its the PSU fan that is making all the noise, changing the fan speed does nothing.
So to whoever is having the same problem, you cannot change the speed on your fan and the PSU fan is the one making noise, try to get it cleaned since mine is full of dust.
2 REPLIES 2
Igor28
Message 2 of 3
Message 2 of 3
Hi @Filce123
Do you have the MSN reference of your laptop?
Thank you.
Filce123
Message 3 of 3
Message 3 of 3
2 REPLIES 2
