ERAZER X7853 MD60605, Bios + Original EC, help!
15 ANTWOORDEN 15
nicke85
Bericht 1 van 16
11.957 Weergaven
Bericht 1 van 16
11.957 Weergaven
Hello,
I have Medion Erazer X7853 MD60605, and after i updated wrong EC from Medion service i have to find way to bring notebook in life.
After two months i ordered tools to install EC file after nobody knows how to help me. I have now XMG Bios in Erazer and XMG EC.
But i lost my blue frame around mousepad and 2 of 3 audio ports dont have light.
I want to turn back to original Medion EC and Bios.
Does anybody have backup of EC file or knows where to download that EC file for Erazer X7853.
Kind regards
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
nicke85
Bericht 11 van 16
11.811 Weergaven
Bericht 11 van 16
11.811 Weergaven
I have solved problem,
Have found the lastest Medion Erazer X7853 (X7851) bios and installed it.
Blue mouse frame LED can be enabled / disabled by Fn+2, and fan EC / MAX switch with Fn+1.
Also it works with EC file from XMG, bios just must be from Medion 🙂
Tags (1)
15 ANTWOORDEN 15
Gehringer
Retired
Bericht 2 van 16
7.941 Weergaven
Bericht 2 van 16
7.941 Weergaven
Hi @nicke85 ,
can you please inform the MSN number of your product?
Also, have you checked Medion Service website?
The downloads available for your product should be listed there.
Which BIOS version are you looking for?
Regards,
Gehringer
nicke85
Bericht 3 van 16
7.938 Weergaven
Bericht 3 van 16
7.938 Weergaven
Hello @Gehringer  ,
there is no bios version for my notebook version i have look on DE and UK sites and written mails.
But Medion service just told to sent back notebook to get new motherboard,
anyway i found my way to install XMG bios version and EC firmware file and it work,
but still want back Medion version because of EC firmware to have blue frame around mousepad and to have leds on audio inputs.
My MSN is 30022756.
I'm  looking for lastest working EC firmware file and bios version from Medion
Kind regards
Gehringer
Retired
Bericht 4 van 16
7.906 Weergaven
Bericht 4 van 16
7.906 Weergaven
Hi @nicke85 ,
what is your current version and which version you are looking for?
Regards,
Gehringer
nicke85
Bericht 5 van 16
7.867 Weergaven
Bericht 5 van 16
7.867 Weergaven
hi @Gehringer ,
I use BIOS + EC from this page
https://download.schenker-tech.de/package/xmg-p707/
files:
P507_1070_P707_1060_1070_2017_EC_1.05.05_xmg.zip
P507_GTX1070_P707_GTX10x0_2017_BIOS_1.05.14.zip
It works ok except i don't have mouse frame controls light and lights from microphone port.
I have looking the same from Medion for MD60605 model BIOS + original EC.
Regards
nicke85
Bericht 6 van 16
7.849 Weergaven
Bericht 6 van 16
7.849 Weergaven
Anybody have EC file and bios from MD60605?
Medion service is very poor.
Regards
nicke85
Bericht 7 van 16
7.646 Weergaven
Bericht 7 van 16
7.646 Weergaven
From my dump file i see that I have looking for EC file
1.05.01ME1
that was installed.
Maybe someone have or can make a backup of bios and EC
model is Medion Erazer X7853 MD60605 its Clevo P670S-GM, but with ME1 EC fro frame and audio jack lights.
Kind regard
nicke85
Bericht 8 van 16
7.628 Weergaven
Bericht 8 van 16
7.628 Weergaven
@Gehringer , @Fishtown
MEDION need one update for X7853 BIOS + EC original to support also XMP 2.0 so-dimms (e.g 4000Mhz),
there is no official update of bios and EC from beggining
NB BB CLV P670HS-GM X7853 ERAZER black rub
MSN: 3002 2756
Why is that? Does somebody have backup or to share saved files?
Kind regards
Gehringer
Retired
Bericht 9 van 16
7.619 Weergaven
Bericht 9 van 16
7.619 Weergaven
Hi @nicke85 ,
currently Medion does not offer links to drivers and firmwares updates.
It recommends using the update feature on Windows 10 because it makes it easier to find the latest software, firmware updates and new hardware drivers, since It detects most devices automatically and installs the necessary drivers, software and firmware updates when you're connected to the Internet.
Regards,
Gehringer
nicke85
Bericht 10 van 16
7.611 Weergaven
Bericht 10 van 16
7.611 Weergaven
Bad for MEDION good for XMG,
Seems that i have fully converted my Medion Erazer X7853 MD60605 to XMG P707 PRO, lool
Anyway XMG looks more stable than Medion, especially in OC, in its base its the same notebook Clevo P670HS-G(M)..
Thx for support..
15 ANTWOORDEN 15
