ERAZER Engineered P10 (MD34951)
2 REPLIES 2
hennix
Message 1 of 3
Message 1 of 3
Hi
Just got the pc, overall satisfied.
But the CPU fan is too loud, and cant find it using SpeedFan.
Any utility that works to fix this? Bios didnt work, can only enable or disable auto controll, but it sets it very high on rpm.
Edit: X... not P >.<
2 REPLIES 2
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @hennix ,
I think this post here may help you.
If it does not, there are other posts regarding the control of the fan.
Regards,
Gehringer
hennix
Message 3 of 3
Message 3 of 3
@Gehringer
X10 is the one I have, dont know if P10 is a laptop.
But have not found anything to control the fan. A BIOS update is needed, since no program can see the CPU-fan.
Or this "Medion Control Center" that some people talk about that screams with it absence for the Engineer x10 model.
2 REPLIES 2
