Erazer X7833 Control Fan Turbo
1 REPLY 1
tazplan
Message 1 of 2
Message 1 of 2
Hello community,
I have a physical button to start the fan turbo on my Erazer X7833, but I want to start the fan turbo by a simple click. Is there any way to control the fan speed ? or anyway to force to active the turbo all the time? (I tried SpeedFan freeware but it does not recognize my fan).
Regards
1 REPLY 1
Bodgekin
Message 2 of 2
Message 2 of 2
Hi @tazplan,
I don't think there is a way to controll the physical button for the Cooler Boost with software, it seems to be MSI technology.  See here for someone trying to do the same thing. As I understand it the cooler boost just makes your fans run at maximum RPM, so you should be able to reach the same effect with some fancontroller software, if you can find one that recognises your fans.
Kind regards,
Bart
1 REPLY 1
