Deputy 15 P1 Crashing
13 REPLIES 13
GTAH
Message 1 of 14
Message 1 of 14
Hello,
My Deputy 15 P1 is crashing when 5 mins into all games
-arena breakout
-delta force
so so annoying, how do i fix this?
W11 all up to date and same with NVidia graphics😡
Thnaks.
13 REPLIES 13
GTAH
Message 11 of 14
Message 11 of 14
didnt move off 1% so had to restart with power button.
GTAH
Message 12 of 14
Message 12 of 14
Search the error above and did all the below;
How to troubleshoot and fix the error
Run a System File Checker (SFC) scan: This built-in Windows tool can detect and repair corrupted system files.
Open Command Prompt as an administrator.
Type sfc /scannow and press Enter.
Update device drivers: Ensure all your drivers are up to date, especially for your graphics card, network, and hard disk controllers. Check for memory issues: Run the Windows Memory Diagnostic tool to check your RAM for errors. Check your hard drive for errors: Open Command Prompt as an administrator and run the command chkdsk /f /r.
 And then crashed again when playing this morning:
GTAH
Message 13 of 14
Message 13 of 14
Crashed again this morning after doing the following error fixes:
How to troubleshoot and fix the error:
Type sfc /scannow and press Enter.- NO ISSUES
Check for memory issues: Run the Windows Memory Diagnostic tool to check your RAM for errors.- NO ISSUES
Check your hard drive for errors: Open Command Prompt as an administrator and run the command chkdsk /f /r.- DID HAVE TO FIX A FEW
Mastermind
Message 14 of 14
Message 14 of 14
Hi @GTAH ,
that´s not very good to hear, but I´m now wondering if you already also performed a test with the medion diagnostics app, which can be downloaded here.
After doing the test we might receive some more details of the problem.
Cheers
13 REPLIES 13
