CPU upgrade for Erazer X7847
21 ANTWORTEN 21
FGS
Nachricht 1 von 22
18.681 Aufrufe
Nachricht 1 von 22
18.681 Aufrufe
Hi,
I have a MEDION ERAZER X7847 MD 60475, with a CPU i7-6820HK; I would like to know if it is possible to upgrade this CPU, and what will be the highest performance CPU that I could install instead the original one, in order to increase the number of cores of the CPU.
On the other hand, if it were not possible to upgrade the CPU, I also would like to know how can I increase the CPU and RAM speed using the overclocking function.
Thank you very much for your support, and best regards.
Fernando, from Madrid (SPAIN).
FGS
Nachricht 22 von 22
11.175 Aufrufe
Nachricht 22 von 22
11.175 Aufrufe
Hi,
Finally I changed my pair of SATA SSD in RAID 0 for one PCIe SSD; and when I removed both SATA SSD disks and plug in the PCIe SSD in the correct m2 socket, it works OK. Unfortunately I tried to manage a image of my RAID 0 disks to recover it over the new PCI e disk using AOMEI software, and I have no success: finally, I had to reinstall the whole OS. I tried to recover the image of the RAID 0 into the PCIe disk, but my laptop gets hanged when it tried to boot from the recovered image. I do not know if I did something wrong, but after several  attempts, I gave up and resigned myself to reinstalling windows from scratch.
In any case, thank you very much for your support and your help.
FGS.
21 ANTWORTEN 21
Gehringer
Retired
Nachricht 2 von 22
9.285 Aufrufe
Nachricht 2 von 22
9.285 Aufrufe
Hi @FGS ,
are you willing to perform board level repair?
Regards,
Gehringer
FGS
Nachricht 3 von 22
9.282 Aufrufe
Nachricht 3 von 22
9.282 Aufrufe
Hi, Gehringer:
If it were necessary, yes. Specially if the increase in performance were significant.
Regards,
FGS.
Gehringer
Retired
Nachricht 4 von 22
9.277 Aufrufe
Nachricht 4 von 22
9.277 Aufrufe
Hi @FGS ,
unfortunatelly Medion can't recommend any modification on original products but I hope our FORUM experts will be able to help you.
Regards,
Gehringer
Nachricht 5 von 22
9.273 Aufrufe
Nachricht 5 von 22
9.273 Aufrufe
Hola @FGS  y bienvenido
You have a CLV P670RP6-M
Doesn't look like it, see here under Page 1-2 Specification (Processor Options)
https://my.hidrive.com/share/yze8mg-wf8#$/CLEVO%20Service%20Manual%20Books/P_Series/P6_Series/P6xxRx...
adiós / bye Fishtown
FGS
Nachricht 6 von 22
9.263 Aufrufe
Nachricht 6 von 22
9.263 Aufrufe
Thank you very much, Fishtown for your message:
The service manual is really interesting, but concerning the upgrade of the Laptop, only gives two possibilities, both of then related with 6ª i7 generation: Are there no other possibility with a powerful processor? Are there any possibility of upgrading the whole MB?
Regards,
FGS.
FGS
Nachricht 7 von 22
9.238 Aufrufe
Nachricht 7 von 22
9.238 Aufrufe
Hi again, Fishtown:
Reading the service manual that you kindly has made available in this thread, I could see that I can use and PCIe SSd in m2 slot 2; then: Could I use for instance a Samsun 970 EVO NMeV in m2 slot 2 as boot disk? Can you confirm this point? This will be also a good upgrade!
Regards,
Fernando.
Nachricht 8 von 22
9.182 Aufrufe
Nachricht 8 von 22
9.182 Aufrufe
Hi @FGS
your question: Can you confirm this point?
answer: yes and no
MSN 30022356/ X7847 (MD 60475) ES
you have:
4 x 8192 MB DDR4 SO-DIMM
(PC4-17000/2133 MHz)
(4/4 belegt; 64 GB max.)
and
1 x HDD 1,5 TB SATA
1x SSD M.2 (2280) 256GB Phision SATA
look at Page 1-3 Spezifikation:
M.2 SSD Limitation
When slot 3 has an M.2 SATA SSD installed, then slot 2 will not be avail-able for M.2 PCIe SSDs.
so does not work.
unless the SSD SATA comes out completely and your operating system comes new to the PCIe
bye Fishtown
driver:
https://www.medion.com/de/service/product-detail/30022356
Nachricht 9 von 22
9.170 Aufrufe
Nachricht 9 von 22
9.170 Aufrufe
Hi @FGS
overclocking look at control center
https://intranet.medion.com/ftp/pdf/bda_40060974.pdf
Page: 27
Fn + ESC
Control Center
Aumento de la frecuencia del procesador con el botón del Control Center
`Abra el Control Center pulsando Fn + ESC o haciendo doble clic en el icono correspondiente de la barra de tareas.
`Seleccione la pestaña Gaming > CPU o GPU Overclocking.
Si su procesador no permite un aumento de frecuen-cia, estas opciones no estarán a su disposición.
bye Fishtown
FGS
Nachricht 10 von 22
9.153 Aufrufe
Nachricht 10 von 22
9.153 Aufrufe
Thank you very much Fishtown for your message:
I have to admit that I never knew how to use Control Center application to manage the overcloking feature of my laptop; there are a lot of wipers that I do not know what they are for: Are there any manual or documento in which all this possible controls are explained??
Best Regards,
Fernando.
21 ANTWORTEN 21
