le 01.06.2021 14:20
le 01.06.2021 14:20
Hi,
I have a MEDION ERAZER X7847 MD 60475, with a CPU i7-6820HK; I would like to know if it is possible to upgrade this CPU, and what will be the highest performance CPU that I could install instead the original one, in order to increase the number of cores of the CPU.
On the other hand, if it were not possible to upgrade the CPU, I also would like to know how can I increase the CPU and RAM speed using the overclocking function.
Thank you very much for your support, and best regards.
Fernando, from Madrid (SPAIN).
le 29.06.2021 10:08
le 29.06.2021 10:08
Hi,
Finally I changed my pair of SATA SSD in RAID 0 for one PCIe SSD; and when I removed both SATA SSD disks and plug in the PCIe SSD in the correct m2 socket, it works OK. Unfortunately I tried to manage a image of my RAID 0 disks to recover it over the new PCI e disk using AOMEI software, and I have no success: finally, I had to reinstall the whole OS. I tried to recover the image of the RAID 0 into the PCIe disk, but my laptop gets hanged when it tried to boot from the recovered image. I do not know if I did something wrong, but after several attempts, I gave up and resigned myself to reinstalling windows from scratch.
In any case, thank you very much for your support and your help.
FGS.
le 02.06.2021 10:11
le 02.06.2021 10:45
le 02.06.2021 10:45
Hi, Gehringer:
If it were necessary, yes. Specially if the increase in performance were significant.
Regards,
FGS.
le 02.06.2021 12:54
le 03.06.2021 21:34
le 03.06.2021 21:34
Hola @FGS y bienvenido
You have a CLV P670RP6-M
Doesn't look like it, see here under Page 1-2 Specification (Processor Options)
adiós / bye Fishtown
le 04.06.2021 07:55
le 04.06.2021 07:55
Thank you very much, Fishtown for your message:
The service manual is really interesting, but concerning the upgrade of the Laptop, only gives two possibilities, both of then related with 6ª i7 generation: Are there no other possibility with a powerful processor? Are there any possibility of upgrading the whole MB?
Regards,
FGS.
le 04.06.2021 12:31
le 04.06.2021 12:31
Hi again, Fishtown:
Reading the service manual that you kindly has made available in this thread, I could see that I can use and PCIe SSd in m2 slot 2; then: Could I use for instance a Samsun 970 EVO NMeV in m2 slot 2 as boot disk? Can you confirm this point? This will be also a good upgrade!
Regards,
Fernando.
le 04.06.2021 19:18
le 04.06.2021 19:18
Hi @FGS
your question: Can you confirm this point?
answer: yes and no
MSN 30022356/ X7847 (MD 60475) ES
you have:
4 x 8192 MB DDR4 SO-DIMM
(PC4-17000/2133 MHz)
(4/4 belegt; 64 GB max.)
and
1 x HDD 1,5 TB SATA
1x SSD M.2 (2280) 256GB Phision SATA
look at Page 1-3 Spezifikation:
M.2 SSD Limitation
When slot 3 has an M.2 SATA SSD installed, then slot 2 will not be avail-able for M.2 PCIe SSDs.
so does not work.
unless the SSD SATA comes out completely and your operating system comes new to the PCIe
bye Fishtown
driver:
https://www.medion.com/de/service/product-detail/30022356
le 05.06.2021 14:16
le 05.06.2021 14:16
Hi @FGS
overclocking look at control center
https://intranet.medion.com/ftp/pdf/bda_40060974.pdf
Page: 27
Fn + ESC
Control Center
Aumento de la frecuencia del procesador con el botón del Control Center
`Abra el Control Center pulsando Fn + ESC o haciendo doble clic en el icono correspondiente de la barra de tareas.
`Seleccione la pestaña Gaming > CPU o GPU Overclocking.
Si su procesador no permite un aumento de frecuen-cia, estas opciones no estarán a su disposición.
bye Fishtown
le 06.06.2021 11:32
le 06.06.2021 11:32
Thank you very much Fishtown for your message:
I have to admit that I never knew how to use Control Center application to manage the overcloking feature of my laptop; there are a lot of wipers that I do not know what they are for: Are there any manual or documento in which all this possible controls are explained??
Best Regards,
Fernando.
Subject | Author | Posted | |
01.03.2021 00:38 | |||
12.07.2022 06:56 | |||
15.09.2020 16:58 | |||
20.06.2018 12:38 |
