CPU upgrade for Erazer X7847
21 RÉPONSES 21
FGS
Message 1 sur 22
11 381 Visites
Message 1 sur 22
11 381 Visites
Hi,
I have a MEDION ERAZER X7847 MD 60475, with a CPU i7-6820HK; I would like to know if it is possible to upgrade this CPU, and what will be the highest performance CPU that I could install instead the original one, in order to increase the number of cores of the CPU.
On the other hand, if it were not possible to upgrade the CPU, I also would like to know how can I increase the CPU and RAM speed using the overclocking function.
Thank you very much for your support, and best regards.
Fernando, from Madrid (SPAIN).
1 SOLUTION APPROUVÉE
Solutions acceptées
FGS
Message 22 sur 22
6 702 Visites
Message 22 sur 22
6 702 Visites
Hi,
Finally I changed my pair of SATA SSD in RAID 0 for one PCIe SSD; and when I removed both SATA SSD disks and plug in the PCIe SSD in the correct m2 socket, it works OK. Unfortunately I tried to manage a image of my RAID 0 disks to recover it over the new PCI e disk using AOMEI software, and I have no success: finally, I had to reinstall the whole OS. I tried to recover the image of the RAID 0 into the PCIe disk, but my laptop gets hanged when it tried to boot from the recovered image. I do not know if I did something wrong, but after several  attempts, I gave up and resigned myself to reinstalling windows from scratch.
In any case, thank you very much for your support and your help.
FGS.
21 RÉPONSES 21
Gehringer
Retired
Message 2 sur 22
5 739 Visites
Message 2 sur 22
5 739 Visites
Hi @FGS ,
are you willing to perform board level repair?
Regards,
Gehringer
FGS
Message 3 sur 22
5 736 Visites
Message 3 sur 22
5 736 Visites
Hi, Gehringer:
If it were necessary, yes. Specially if the increase in performance were significant.
Regards,
FGS.
Gehringer
Retired
Message 4 sur 22
5 731 Visites
Message 4 sur 22
5 731 Visites
Hi @FGS ,
unfortunatelly Medion can't recommend any modification on original products but I hope our FORUM experts will be able to help you.
Regards,
Gehringer
Message 5 sur 22
5 727 Visites
Message 5 sur 22
5 727 Visites
Hola @FGS  y bienvenido
You have a CLV P670RP6-M
Doesn't look like it, see here under Page 1-2 Specification (Processor Options)
https://my.hidrive.com/share/yze8mg-wf8#$/CLEVO%20Service%20Manual%20Books/P_Series/P6_Series/P6xxRx...
adiós / bye Fishtown
FGS
Message 6 sur 22
5 717 Visites
Message 6 sur 22
5 717 Visites
Thank you very much, Fishtown for your message:
The service manual is really interesting, but concerning the upgrade of the Laptop, only gives two possibilities, both of then related with 6ª i7 generation: Are there no other possibility with a powerful processor? Are there any possibility of upgrading the whole MB?
Regards,
FGS.
FGS
Message 7 sur 22
5 692 Visites
Message 7 sur 22
5 692 Visites
Hi again, Fishtown:
Reading the service manual that you kindly has made available in this thread, I could see that I can use and PCIe SSd in m2 slot 2; then: Could I use for instance a Samsun 970 EVO NMeV in m2 slot 2 as boot disk? Can you confirm this point? This will be also a good upgrade!
Regards,
Fernando.
Message 8 sur 22
5 636 Visites
Message 8 sur 22
5 636 Visites
Hi @FGS
your question: Can you confirm this point?
answer: yes and no
MSN 30022356/ X7847 (MD 60475) ES
you have:
4 x 8192 MB DDR4 SO-DIMM
(PC4-17000/2133 MHz)
(4/4 belegt; 64 GB max.)
and
1 x HDD 1,5 TB SATA
1x SSD M.2 (2280) 256GB Phision SATA
look at Page 1-3 Spezifikation:
M.2 SSD Limitation
When slot 3 has an M.2 SATA SSD installed, then slot 2 will not be avail-able for M.2 PCIe SSDs.
so does not work.
unless the SSD SATA comes out completely and your operating system comes new to the PCIe
bye Fishtown
driver:
https://www.medion.com/de/service/product-detail/30022356
Message 9 sur 22
5 624 Visites
Message 9 sur 22
5 624 Visites
Hi @FGS
overclocking look at control center
https://intranet.medion.com/ftp/pdf/bda_40060974.pdf
Page: 27
Fn + ESC
Control Center
Aumento de la frecuencia del procesador con el botón del Control Center
`Abra el Control Center pulsando Fn + ESC o haciendo doble clic en el icono correspondiente de la barra de tareas.
`Seleccione la pestaña Gaming > CPU o GPU Overclocking.
Si su procesador no permite un aumento de frecuen-cia, estas opciones no estarán a su disposición.
bye Fishtown
FGS
Message 10 sur 22
5 607 Visites
Message 10 sur 22
5 607 Visites
Thank you very much Fishtown for your message:
I have to admit that I never knew how to use Control Center application to manage the overcloking feature of my laptop; there are a lot of wipers that I do not know what they are for: Are there any manual or documento in which all this possible controls are explained??
Best Regards,
Fernando.
21 RÉPONSES 21
