on 21.12.2022 17:48
on 21.12.2022 17:48
I recently got a new Medion Erazer Defender P10 and i've noticed and checked, that the CPU is bottlecapping the laptop. It's quite sad that the CPU limits the GPU as it has great potential, so i started looking for a new CPU but quickly discovered that lots of issues arrise. I want to upgrade from the current Intel Core i5 - 10300H to an Intel Core i3 - 12100F. However i can not find anywhere if the CPU is compatible with the motherboard (sockets and etc), and i've even seen that the CPU can not be upgraded at all??? It would be a big shame if i have to keep using my bottlecapped laptop knowing that it could be running much better with a CPU that is slightly more fit for the graphics card. I really hope the rumors of the CPU's being stuck to the motherboard isn't true, as this would honestly instantly make me loose all my respect for Medion. Something as simple as upgrading a CPU shouldn't be this hard, definitely not when the standard CPU is not capable enough.
10.01.2023 12:34 - edited 24.03.2023 15:09
Hello @NickyHens,
With your laptop it is not possible to replace the CPU without special equipment.
Greetings,
EastClintwood
on 22.12.2022 12:27
on 22.12.2022 12:27
Hello @NickyHens, and welcome to the community.
Please send us the 8-digit MSN, which is usually located on the bottom of the device.
Where did you get this info from? It would be helpful to know the source. 🙂
Regards,
EastClintwood
on 06.01.2023 09:47
on 06.01.2023 09:47
I don’t remember exactly where I saw that the cpu might not be upgradable, I just remember seeing somewhere here on the support website people talk about the CPU being soldered to the motherboard on some Medion laptops. The MSN number I found is 30033042
Hello @NickyHens,
Greetings,
EastClintwood
on 11.01.2023 14:22
