Brand new p15603 FAN going crazy
13 ANTWOORDEN 13
mperus
Bericht 1 van 14
6.612 Weergaven
Bericht 1 van 14
6.612 Weergaven
Just bought it and am at the point of installing software - Office 365, VLC and stuff and fan is constantly at 80 % or more, which is VERY loud. What to do ? I cant even imagine what will happen when i try an actual game.
13 ANTWOORDEN 13
Gehringer
Retired
Bericht 2 van 14
5.092 Weergaven
Bericht 2 van 14
5.092 Weergaven
Hi @mperus and welcome to the forum.
Can you please tell me what is the MSN number of your NB?
It is an 8 digits number printed in the label underneath it (usually starting by 300 or 500).
Also, does the fan start to go loud from the start of your PC or only when you start downloading software?
Regards,
Gehringer
mperus
Bericht 3 van 14
5.086 Weergaven
Bericht 3 van 14
5.086 Weergaven
hello,
MSN is 30027187, and fan starts going crazy whenever I install something or play and game. When computer starts it's ok.
Gehringer
Retired
Bericht 4 van 14
5.074 Weergaven
Bericht 4 van 14
5.074 Weergaven
Hi @mperus ,
have you been monitoring the internal temperature of your NB? If so, how is it?
Also, can you check that these softwares you are running are not set to be run in the high performance mode or that this is not the default mode set for running programs?
Regards,
Gehringer
mperus
Bericht 5 van 14
5.060 Weergaven
Bericht 5 van 14
5.060 Weergaven
Everything on default, NB on balanced, when firefox is opened right now with 4 tabs it 45 °C. When installing something there is an instant jump to 70.
Gehringer
Retired
Bericht 6 van 14
5.055 Weergaven
Bericht 6 van 14
5.055 Weergaven
Hi @mperus ,
please check that you have the latest Windows and Drivers updates installed.
After that, you can download and run our self diagnose app (find it here) to check your NB for any faults.
If nothing comes up from that, can you please tell me which is the BIOS version you are currently on?
Regards,
Gehringer
mperus
Bericht 7 van 14
5.010 Weergaven
Bericht 7 van 14
5.010 Weergaven
no, didn't fix anything. i tried every possible driver combination to improve anything, laptop is still loud as hell.
BIOSVersion
{"MEDION - 0", "1.07.06RME4_00005", "INSYDE Corp. - 58042004"}
Gehringer
Retired
Bericht 8 van 14
5.003 Weergaven
Bericht 8 van 14
5.003 Weergaven
Hi @mperus,
I would recommend you to back your data up and then perform a factory settings reset (instructions on page 38 of the user guide here).
Let me know if it has solved the issue.
Regards,
Gehringer
mperus
Bericht 9 van 14
5.000 Weergaven
Bericht 9 van 14
5.000 Weergaven
hello,
did that also, no change.
mperus
Bericht 10 van 14
4.989 Weergaven
Bericht 10 van 14
4.989 Weergaven
made a screenshot, atom btw. is a text editor - that should be something a gaming laptop is able to handle.
13 ANTWOORDEN 13
