Brand new p15603 FAN going crazy
13 RÉPONSES 13
mperus
Message 1 sur 14
7 303 Visites
Message 1 sur 14
7 303 Visites
Just bought it and am at the point of installing software - Office 365, VLC and stuff and fan is constantly at 80 % or more, which is VERY loud. What to do ? I cant even imagine what will happen when i try an actual game.
13 RÉPONSES 13
Gehringer
Retired
Message 2 sur 14
5 571 Visites
Message 2 sur 14
5 571 Visites
Hi @mperus and welcome to the forum.
Can you please tell me what is the MSN number of your NB?
It is an 8 digits number printed in the label underneath it (usually starting by 300 or 500).
Also, does the fan start to go loud from the start of your PC or only when you start downloading software?
Regards,
Gehringer
mperus
Message 3 sur 14
5 565 Visites
Message 3 sur 14
5 565 Visites
hello,
MSN is 30027187, and fan starts going crazy whenever I install something or play and game. When computer starts it's ok.
Gehringer
Retired
Message 4 sur 14
5 553 Visites
Message 4 sur 14
5 553 Visites
Hi @mperus ,
have you been monitoring the internal temperature of your NB? If so, how is it?
Also, can you check that these softwares you are running are not set to be run in the high performance mode or that this is not the default mode set for running programs?
Regards,
Gehringer
mperus
Message 5 sur 14
5 539 Visites
Message 5 sur 14
5 539 Visites
Everything on default, NB on balanced, when firefox is opened right now with 4 tabs it 45 °C. When installing something there is an instant jump to 70.
Gehringer
Retired
Message 6 sur 14
5 534 Visites
Message 6 sur 14
5 534 Visites
Hi @mperus ,
please check that you have the latest Windows and Drivers updates installed.
After that, you can download and run our self diagnose app (find it here) to check your NB for any faults.
If nothing comes up from that, can you please tell me which is the BIOS version you are currently on?
Regards,
Gehringer
mperus
Message 7 sur 14
5 489 Visites
Message 7 sur 14
5 489 Visites
no, didn't fix anything. i tried every possible driver combination to improve anything, laptop is still loud as hell.
BIOSVersion
{"MEDION - 0", "1.07.06RME4_00005", "INSYDE Corp. - 58042004"}
Gehringer
Retired
Message 8 sur 14
5 482 Visites
Message 8 sur 14
5 482 Visites
Hi @mperus,
I would recommend you to back your data up and then perform a factory settings reset (instructions on page 38 of the user guide here).
Let me know if it has solved the issue.
Regards,
Gehringer
mperus
Message 9 sur 14
5 479 Visites
Message 9 sur 14
5 479 Visites
hello,
did that also, no change.
mperus
Message 10 sur 14
5 468 Visites
Message 10 sur 14
5 468 Visites
made a screenshot, atom btw. is a text editor - that should be something a gaming laptop is able to handle.
13 RÉPONSES 13
