BIOS Update and GPU Limit Throttling
0 REPLIES 0
neneci
Traveler
Message 1 of 1
Message 1 of 1
Hello everyone
i would ask to mods or someone in the community if there are ways to fix those 2 main problems i have with my Medion Erazer Hunter x10 product number 10023964.
1st problem is the BIOS update, since this motherboard has installed a different BIOS from the one you can find on the MSI website i can not update it since the motherboard can not find the files inside the flashdrive. I have seen different thread about this problem and different solution but i wanted to know which one is the right one for my computer. @Andi
2nd problem is the Limit throttling, my GPU is always on limit throttling and when it start to work hard like 70-80% the speed of it decrease a lot. Right now i have set my CPU (Intel i9-10900KF) at 5 GHz but when the load work is really heavy it decrease and reaches like 4 GHz. I would like to know what's the problem and how to solve it. The cooling system is not good enough for the CPU? The power supply is not good enough?
Thanks to everyone that will help me
Best regards
0 REPLIES 0
0 REPLIES 0
