27.05.2025 10:10 - edited 27.05.2025 10:10
I installed the medium control center again and it doesn't work, in the application even when turning it on and off, the lights remain off and do not respond to any light color changes.
I Have already reset the pc, restored it and nothing worked.
on 28.05.2025 08:41
on 28.05.2025 08:41
Hi @TFGL ,
Step 1: Basic Hardware Checks
Check RGB Fan Cables:
Open the case and inspect the RGB fan cables.
Ensure they're properly connected to either:
A dedicated RGB controller,
Or to an ARGB header on the motherboard (usually marked JRGB, ARGB, or JRAINBOW).
Power Supply to the Controller:
Make sure the controller (if present) is getting power. If it draws SATA power or Molex, check those connections.
Reset the RGB Controller (if present):
Some controllers have a reset or sync button—try pressing it.
Disconnect the PC from power and hold the power button for 10 seconds to clear residual power.
Step 2: Software Troubleshooting
Uninstall MEDION Control Center Completely:
Use Revo Uninstaller or similar to do a full uninstall (including leftover registry keys).
Reboot your PC.
Reinstall the Latest Version:
Download the latest MEDION Control Center or Erazer Gaming Center from MEDION's official support site.
Install it and reboot.
Check for Conflicts:
If you also have software like MSI Mystic Light, ASUS Aura Sync, Gigabyte RGB Fusion, OpenRGB, or Corsair iCUE, they may conflict with MEDION’s software. Disable or uninstall them temporarily.
