All RGB Lights Fans of my Erazer Bandit MD35462 Dont Work Anymore!
1 REPLY 1
TFGL
Message 1 of 2
Message 1 of 2
My erazer bandit MD35462 stopped turning on the RGB lights of the fans, The control application crashed, the lights remained permanently blue and when I turned off the PC, when I turned it on again, no more lights came on.
I installed the medium control center again and it doesn't work, in the application even when turning it on and off, the lights remain off and do not respond to any light color changes.
I Have already reset the pc, restored it and nothing worked.
1 REPLY 1
Igor28
Message 2 of 2
Message 2 of 2
Hi @TFGL ,
Step 1: Basic Hardware Checks
  1. Check RGB Fan Cables:
    • Open the case and inspect the RGB fan cables.
    • Ensure they're properly connected to either:
      • A dedicated RGB controller,
      • Or to an ARGB header on the motherboard (usually marked JRGB, ARGB, or JRAINBOW).
  2. Power Supply to the Controller:
    • Make sure the controller (if present) is getting power. If it draws SATA power or Molex, check those connections.
  3. Reset the RGB Controller (if present):
    • Some controllers have a reset or sync button—try pressing it.
    • Disconnect the PC from power and hold the power button for 10 seconds to clear residual power.
Step 2: Software Troubleshooting
  1. Uninstall MEDION Control Center Completely:
    • Use Revo Uninstaller or similar to do a full uninstall (including leftover registry keys).
    • Reboot your PC.
  2. Reinstall the Latest Version:
  3. Check for Conflicts:
    • If you also have software like MSI Mystic Light, ASUS Aura Sync, Gigabyte RGB Fusion, OpenRGB, or Corsair iCUE, they may conflict with MEDION’s software. Disable or uninstall them temporarily.
1 REPLY 1
