Additional SSD in Engineer X10
2 REPLIES 2
Maxwellsmart
Message 1 of 3
Message 1 of 3
Hi there,
painfully made my way through a 2.5” SSD (case has no visible SATA cables, just the wider ones to power a drive), then an M.2 PCIe (same mistake as OP in the attached post) and now a FIKWOT FN203 M.2 2280 SATA Drive in the pursuit of adding an additional 2TB to my Medion Engineer X10 with the B660H7-M20 Board.
Installed it in the only visible bay parallel to the RAM.
Sadly having the same story as I had before - nothing in BIOS therefore nothing in the Disk Management.
About to give up and order an external USB Drive..
Any suggestions about what I’m doing wrong?
This post was a lead but the solution sadly doesn’t work for me.
https://community.medion.com/t5/Desktop-PC-All-In-One/Connecting-adding-m-2-ssd-to-MEDION-ERAZER-REC...
2 REPLIES 2
Message 2 of 3
Message 2 of 3
@Maxwellsmart
Hi, you first should state the MSN number of your PC.
Concerning the newly built in SSD SATA, I only can think of the SSD is not seated properly.  Redo this. Or the SSD is a defectiv.
Maxwellsmart
Message 3 of 3
Message 3 of 3
I’m not sure what exactly the MSN number is but it may be MD34865 - it’s this PC
https://www.aldi-onlineshop.de/p/high-end-gaming-pc-engineer-x10-md34865-1019937/
I am very sure the SSD is seated properly so it may be defective. Will try reseating it one more time and then sending it back I guess.
thanks for the help 🙂
2 REPLIES 2
