AGESA 1.0.0.6 Bios update for P2A4-EM ryzen motherobards
17 REPLIES 17
Hercules888
Message 1 of 18
Message 1 of 18
When can we expect a Bios update with the AGESA 1.0.0.6 microcode?
Currently, there are 2 bios revisions found in the wild, being P2A4W0X.109 (ref) andP2A4W0X.107 (ref).
There seems to be one mainboard that is used for most Ryzen systems, being the P2A4-EM, is this correct?
Would it be possible to provide with info on how to get the latest Bios for the P2A4-EM motherboard,
and if the AGESA 1.0.0.6 update will be included?
Thank you very much for any reaction!
17 REPLIES 17
burkm
Explorer
Message 11 of 18
Message 11 of 18
I opened up a new thread for the still non-existent new AGESA BIOS version  1.0.7.x here
https://community.medion.com/t5/ERAZER-Gaming/AGESA-1-0-0-7-1-0-71-1-0-7-1-Bios-update-for-P2A4-EM-r...
Tags (1)
xp15
Message 12 of 18
Message 12 of 18
@Major_ToM
Thank you! I have a question, just to make it sure.
When I have a 64-bit System. Then I should run Wflash64.bat, right ?
Thank you in advance!
Greetings,
xp15
Message 13 of 18
Message 13 of 18
Hi @xp15 ,
you´re absolutely right.
Regards,
Luis_R34
Message 14 of 18
Message 14 of 18
@Major_ToM can you confirm me please, if this Bios update is valid for my computer?
MSN 10022258
DMI BIOS
vendor American Megatrends Inc.
version P2A4W0X.206
date 06/12/2018
ROM size 16384 KB
DMI Baseboard
vendor MEDION
model P2A4-EM
revision 1.0
serial KX1101G71302433
Thank you!
burkm
Explorer
Message 15 of 18
Message 15 of 18
BIOS Version 2.06 has been officially released by Medion for this mainboard some time ago and can be installed through the Firmware entry in the device list of the board.
It will only support the 1st gen of Ryzen processors, thus i.e. the "new" version of the Ryzen 5 1600 (12nm) won't work, just original (14nm) ones.
A newer firmware on is not to be expected any more for this ECS OEM board, thus this mainboard has already reached "end of life" and no further support is to be expected even from Medion as usual.
Luis_R34
Message 16 of 18
Message 16 of 18
Thank you for your answer!
roberpe
Message 17 of 18
Message 17 of 18
Where can I download the latest version of the P2A4-EM motherboard bios from?
I have version 2.02.
Thanks for the help.
burkm
Explorer
Message 18 of 18
Message 18 of 18
Have a look at my previous post. Just use the "firmware" entry in the device table to update the BIOS version.
17 REPLIES 17
