Fans speed on a Erazer Deputy P10
20 RÉPONSES 20
and76
Message 1 sur 21
7 608 Visites
Message 1 sur 21
7 608 Visites
Hello guys.
I have a Medion Erazer Deputy P10 laptop, MD63665. The issue is that the cpu fan automatically raises its frequency, and noise, without gaming or doing tasks that require cpu overload. With hotkeys I manage to decrease its frequency, but it increases again in a few minutes. I reinstalled Windows 11 to version 22H2, but this problem continues. I do not think it is a hardware problem, because with the battery in Saving mode this problem does not appear.
Control Center always shows me the speed of the CPU fans above 6000 RPM, but it doesn't show the speed of the GPU fans.
I would appreciate help.
Andres (Cuba).
1 SOLUTION APPROUVÉE
Solutions acceptées
and76
Message 20 sur 21
6 590 Visites
Message 20 sur 21
6 590 Visites
Folks.
The whole problem was the fan of the GPU stuck, with dust... Solved everything with preventive maintenance, and change of thermal paste.
Thank you all.
20 RÉPONSES 20
Burki48
Message 2 sur 21
3 818 Visites
Message 2 sur 21
3 818 Visites
Hello @and76 and welcome to the community,
please tell us which BIOS version is currently installed on your PC.
Greetings
Burki
and76
Message 3 sur 21
3 811 Visites
Message 3 sur 21
3 811 Visites
Hi.
BIOS version: SMBIOSBIOSVersion
208
Burki48
Message 4 sur 21
3 801 Visites
Message 4 sur 21
3 801 Visites
Hello @and76,
thank you for your feedback.
Please tell us the 8-digit MSN number of your PC or notebook.
Greetings
Burki
and76
Message 5 sur 21
3 793 Visites
Message 5 sur 21
3 793 Visites
Hi Burki.
Many thanks for your kindly answer and support.
MSN 30029942
MODEL. MD63665
Sorry for missing that.
Andres.
Burki48
Message 6 sur 21
3 787 Visites
Message 6 sur 21
3 787 Visites
Hello @and76,
We can offer you the BIOS version 2.11 for your notebook. You can download it here.
Please note that MEDION is not liable for any damage caused by the BIOS update.
Greetings
Burki
and76
Message 7 sur 21
3 780 Visites
Message 7 sur 21
3 780 Visites
Thank you for the file.
Will it improve the fans performance?
How do I upgrade it?
Regards.
Burki48
Message 8 sur 21
3 776 Visites
Message 8 sur 21
3 776 Visites
Hello @and76,
please unzip the downloaded .ZIP file. You will then find 2 folders. Open the folder Windows. In this folder you will find the BIOS update, which can be started directly from Windows. Please make sure that you have connected your notebook to the power supply before you run the BIOS update.
Since the fan control is part of the BIOS, it is obvious that it will be improved by a newer BIOS version.
Greetings
Burki
and76
Message 9 sur 21
3 765 Visites
Message 9 sur 21
3 765 Visites
Dear Burki.
I have successfully updated the BIOS, but the problem persists. I can only control the fan through Control Center...for a while.
I have a screenshot of Control Center.
Burki48
Message 10 sur 21
3 756 Visites
Message 10 sur 21
3 756 Visites
Hello @and76,
in this case, the only thing left to check is whether the fans are possibly clogged with dust. However, this procedure is not so simple and should therefore only be carried out by trained personnel.
Have you loaded the BIOS default values?
Greetings
Burki
20 RÉPONSES 20
