Fans speed on a Erazer Deputy P10
20 ANTWOORDEN 20
and76
Bericht 1 van 21
7.130 Weergaven
Bericht 1 van 21
7.130 Weergaven
Hello guys.
I have a Medion Erazer Deputy P10 laptop, MD63665. The issue is that the cpu fan automatically raises its frequency, and noise, without gaming or doing tasks that require cpu overload. With hotkeys I manage to decrease its frequency, but it increases again in a few minutes. I reinstalled Windows 11 to version 22H2, but this problem continues. I do not think it is a hardware problem, because with the battery in Saving mode this problem does not appear.
Control Center always shows me the speed of the CPU fans above 6000 RPM, but it doesn't show the speed of the GPU fans.
I would appreciate help.
Andres (Cuba).
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
and76
Bericht 20 van 21
6.142 Weergaven
Bericht 20 van 21
6.142 Weergaven
Folks.
The whole problem was the fan of the GPU stuck, with dust... Solved everything with preventive maintenance, and change of thermal paste.
Thank you all.
20 ANTWOORDEN 20
Burki48
Bericht 2 van 21
3.526 Weergaven
Bericht 2 van 21
3.526 Weergaven
Hello @and76 and welcome to the community,
please tell us which BIOS version is currently installed on your PC.
Greetings
Burki
and76
Bericht 3 van 21
3.519 Weergaven
Bericht 3 van 21
3.519 Weergaven
Hi.
BIOS version: SMBIOSBIOSVersion
208
Burki48
Bericht 4 van 21
3.509 Weergaven
Bericht 4 van 21
3.509 Weergaven
Hello @and76,
thank you for your feedback.
Please tell us the 8-digit MSN number of your PC or notebook.
Greetings
Burki
and76
Bericht 5 van 21
3.501 Weergaven
Bericht 5 van 21
3.501 Weergaven
Hi Burki.
Many thanks for your kindly answer and support.
MSN 30029942
MODEL. MD63665
Sorry for missing that.
Andres.
Burki48
Bericht 6 van 21
3.495 Weergaven
Bericht 6 van 21
3.495 Weergaven
Hello @and76,
We can offer you the BIOS version 2.11 for your notebook. You can download it here.
Please note that MEDION is not liable for any damage caused by the BIOS update.
Greetings
Burki
and76
Bericht 7 van 21
3.488 Weergaven
Bericht 7 van 21
3.488 Weergaven
Thank you for the file.
Will it improve the fans performance?
How do I upgrade it?
Regards.
Burki48
Bericht 8 van 21
3.484 Weergaven
Bericht 8 van 21
3.484 Weergaven
Hello @and76,
please unzip the downloaded .ZIP file. You will then find 2 folders. Open the folder Windows. In this folder you will find the BIOS update, which can be started directly from Windows. Please make sure that you have connected your notebook to the power supply before you run the BIOS update.
Since the fan control is part of the BIOS, it is obvious that it will be improved by a newer BIOS version.
Greetings
Burki
and76
Bericht 9 van 21
3.473 Weergaven
Bericht 9 van 21
3.473 Weergaven
Dear Burki.
I have successfully updated the BIOS, but the problem persists. I can only control the fan through Control Center...for a while.
I have a screenshot of Control Center.
Burki48
Bericht 10 van 21
3.464 Weergaven
Bericht 10 van 21
3.464 Weergaven
Hello @and76,
in this case, the only thing left to check is whether the fans are possibly clogged with dust. However, this procedure is not so simple and should therefore only be carried out by trained personnel.
Have you loaded the BIOS default values?
Greetings
Burki
20 ANTWOORDEN 20
