smart Plug setup
5 REPLIES 5
woody50
Message 1 of 6
Message 1 of 6
smart Plug setup
Having problem setting up smart plug.
light flashes, confirm , after 100% does not connect.
Addition failed, please add again or view help.
tried iphone , ipad no luck.
Any thoughts please
5 REPLIES 5
TPFLegionaire
Retired
Message 2 of 6
Message 2 of 6
Hi @woody50
Welcome to the forums.
Just so I can check the right things for you, could you confirm the MSN number of the product and which app (Medion life+ ?) you are using to connect with the plug
I'll do my best to digg up some more info for you. Thank you for your patience.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
woody50
Message 3 of 6
Message 3 of 6
TPFLegionaire
msn50062558
App. Medion life+
thanks
TPFLegionaire
Retired
Message 4 of 6
Message 4 of 6
Hi @woody50
Thank you for the information provided.
I do not know what is causing the issue, several options are open to you, involving various degree of effort.
-Bring it back to the shop , if they still have some, to get it swapped.
-call our warranty services to initiate replacement/refund (if none are available)
Troubleshooting wise a few things to try:
-if it is seen in the APP, initiate a factory reset:
Restore factory settings
− Select the adaptor in the device list.
− Click the button to open
the settings menu for the adaptor.
− Click Reset and confirm your input with Confirm in the pop-up message.
When the factory settings have been restored, the status LED will blink. The adaptor has now been
reset and is ready to be connected to a network again.
-If the issue is Wifi/network related, could you try the plug in a different wifi setting, maybe at a friend house?
-if the issue is rellated to the App, could you try reinstalling? can you test it with an android device?
All in all, I am very sorry for the inconvenience the device has caused you , I hope some of the options above are of some use, do not hesitate to ask for further help or advice if needed.
Cheers!
TPFLegionaire
woody50
Message 5 of 6
Message 5 of 6
TPFLegionaire
Thanks 8 will give it a try
Message 6 of 6
Message 6 of 6
Moin @woody50
possibly the mac address filter in the router disable
5 REPLIES 5
