Smart Plug going offline every few weeks
12 RÉPONSES 12
Madcat
Message 1 sur 13
20 754 Visites
Message 1 sur 13
20 754 Visites
I have 4 MEDION LIFE+ Smart Plug S85225 and have connected them to my home network and registered them with my Google Home. I have noticed that each device goes "offline" (in the Medion Life+ app it says Offline with an icon of a wifi symbol and an X) after a week or 2 of working fine (you can still manually turn them on or off, but they're no longer registering with the app). I then need to remove it from the Medion Life+ app and go through the whole registering a new device process every time. If it was just one device doing this, then I could assume it was faulty, but all 4 devices have now done this
Medion Life+ says I have the latest firmware
WiFi Module: 1.1.2
MCU Module: 1.1.2
12 RÉPONSES 12
Message 11 sur 13
4 315 Visites
Message 11 sur 13
4 315 Visites
Hi @Madcat ,this is a good news
It pleased me to hear that it works now,
although we did not know the exact way to solve the problem.
If you are satisfied please mark your contribution as done.
bye fishtown
Madcat
Message 12 sur 13
21 432 Visites
Message 12 sur 13
21 432 Visites
Thanks @Fishtown it's been stable since my last post and I was just monitoring (I hope I haven't just jinxed myself !! 🙂 )
Perhaps it was the act of leaving the smart plugs unplugged from power for > 24 hrs that did the trick...not sure
Madcat
Message 13 sur 13
21 226 Visites
Message 13 sur 13
21 226 Visites
FYI I found that if there's a power outage and the 2.4 Ghz wireless LAN is disconnected, the plugs can have trouble re-connecting. The fix is to unplug / turn off power to the smart plug for 10 or so minutes (i usually leave them for 30 min) and then turn the power back on / plug them in. They should then re-connect to the wifi
12 RÉPONSES 12
