Md 32035 msn30025225
8 ANTWORTEN 8
Steenrat
Nachricht 1 von 9
3.955 Aufrufe
Nachricht 1 von 9
3.955 Aufrufe
Hi,
I've bought this television couple of years ago.
After joining a other internet provider the netflix button was not working anymore. So i tried a software/firmware update true usb this went wrong i now only see the blue blinking led light. Anyone a solution for this problem.
I had a normal working television except the netflix button now i have no television anymore.
Kind regards
8 ANTWORTEN 8
EastClintwood
Nachricht 2 von 9
3.936 Aufrufe
Nachricht 2 von 9
3.936 Aufrufe
Hi @Steenrat, and welcome to our community.
Another customer had the same problem and was able to fix it with the following steps:
--> Hold Power and Menu button together... Then it flashes twice and as soon as the next one starts flashing (approx. 1 min later) release it.
--> let it flash for approx. 5 min
--> Switch off the main switch if available
--> pull out the plug
--> hold down the power button for 20 seconds
--> Release the power button
--> Insert the plug and switch on the main switch again.
--> Switch on the TV
Please let me know if this solved the problem.
Best regards,
EastClintwood
Nachricht 3 von 9
3.927 Aufrufe
Nachricht 3 von 9
3.927 Aufrufe
Hello @Steenrat and welcome
where does the update come from?
there is none listed for your model on the service page!
Hello @EastClintwood
What does the process you describe do?
Bye Fishtown
EastClintwood
Nachricht 4 von 9
3.923 Aufrufe
Nachricht 4 von 9
3.923 Aufrufe
Hi @Fishtown,
for your information here the corresponding thread: Gelöst: Hallo,habe ein LED TV MD30630. Schaltet nicht mehr... - MEDION Community
Bye,
EastClintwood
Steenrat
Nachricht 5 von 9
3.022 Aufrufe
Nachricht 5 von 9
3.022 Aufrufe
Hallo
Deze oplossing werkte niet.
Heeft toevallig iemand de juiste/huidige software om via usb op de tv te zetten?
Nachricht 6 von 9
3.015 Aufrufe
Nachricht 6 von 9
3.015 Aufrufe
Hallo @Steenrat
Edit: Helaas lijkt het erop dat daar geen firmware is opgeslagen.
doei Fishtown
Steenrat
Nachricht 7 von 9
2.999 Aufrufe
Nachricht 7 von 9
2.999 Aufrufe
Beste,
Is er iemand die de huidige firmware van deze tv me kan bezorgen?
Nachricht 8 von 9
2.885 Aufrufe
Nachricht 8 von 9
2.885 Aufrufe
Hi @Steenrat ,
we would like to have this one solved. Could you please name us the exsact Software version number (like V5.35.4.0) that is currently running on your TV?
Cheers
Steenrat
Nachricht 9 von 9
2.876 Aufrufe
Nachricht 9 von 9
2.876 Aufrufe
Well problem is television is only blinking blue light. And black screen after putting wrong software on there true usb update. Sometimes if i press on the remote the number 5 i see the blue light (infrared light receiver / on television)  blinking faster. So i wonder if i feed the Television the right software by usb i can make it alive again.
The exact software that was on there i don't know because now i inly have a black screen en blue light blinking
8 ANTWORTEN 8
