op 05.07.2021 16:49
op 05.07.2021 16:49
Hello,
I have a mini dishwasher MD 37004 i bought in december 2020. It does not clean anymore. No water being heated and no "jets" of water on top, nor or on the bottom.
The timer goes down as normal, the water gets evacuated fine, but nothing happens other than that.
I emptied it fully, let it dry for 4 days, refilled it with water (1L) + salt and then the cycle water. No changes.
What could I try? There is no error being displayed.
Thanks in advance,
Victoria
op 07.07.2021 09:41
op 07.07.2021 09:41
Hi @victoriam90 ,
in this case I would recommend you to get in touch with your local Medion technical team by phone/form.
There is probably a hardware fault.
Regards,
Gehringer
op 06.07.2021 08:48
op 06.07.2021 08:48
Hi @victoriam90 ,
it may look like a basic troubleshooting, but have you checked the water installation?
Is it closed/blockid?
Does it follow the recommendations on the user manual, particularly in regards to its height in relation to the machine?
Is there any leaking?
Regards,
Gehringer
06.07.2021 19:20 - bewerkt 06.07.2021 19:22
Hi @Gehringer
Thanks for your reply!
I have the dishwasher setup as recommended on the user manuel. Please note i fill the water manually, but the dirty water comes out below my sink, attached with the metal ring with screws.
Exactly like so (dishwasher on kitchen top, tube going down to below the sink):
The water tube is not blocked, i also checked inside the machine below the filter and there is no blocage. Same on the top water filter. Also cleaned the rotating arm as indicated in the manual.
Edit: there is no leaking and has never been.
Kind Regards
Victoria
op 07.07.2021 09:41
op 07.07.2021 09:41
Hi @victoriam90 ,
Regards,
Gehringer
op 07.07.2021 12:22
op 07.07.2021 12:22
Thanks @Gehringer for following up, too bad it's not a fixable issue on my end. I'll contact the support 😊.
I'll accept your answer as a solution. Have a great day.
op 15.11.2021 19:43
op 15.11.2021 19:43
Hello, did you manage to fix this issue. I have the same problem.
op 15.04.2022 21:12
op 15.04.2022 21:12
If there is any fix for this, can you please post it.
I dont have the receipt anymore unfortunately, so i would like to fix it myself!
Best Regards
Tunahan Akgün
op 15.04.2022 21:58
op 15.04.2022 21:58
hello, mine dishwasher started working when i opened it from bottom and gained access to dishwasher pump. I took i out and put back in. I did nothing. I think it was matter of pushing pump rotor manually because it got stuck somehow.
op 28.08.2022 17:47
op 28.08.2022 17:47
Same Problem here. Anyone can tell me, which part I should remove:
@turbine wrote:hello, mine dishwasher started working when i opened it from bottom and gained access to dishwasher pump. I took i out and put back in. I did nothing. I think it was matter of pushing pump rotor manually because it got stuck somehow.
op 16.09.2022 06:57
op 16.09.2022 06:57
Hi @pentos, and welcome to our Community.
It sounds like a defect to me. Please contact the support team.
However, if you agree with @turbine and think that the pump is damaged, it can be ordered from the MEDION Service Shop for €19.95 (article number 50062880).
Best Regards,
EastClintwood
