bios voor ERAZER Bandit E10 (MD 34731) DE
40 REPLIES 40
toelis
Message 1 of 41
Message 1 of 41
Hallo allemaal,
ik heb een
ERAZER Bandit E10 (MD 34731) DE met MSN: 1002 3548.
Ik heb in het Duitse gedeelte van dit forum een post gelezen van Major Tom waarin versie 460H6W0X.107
te vinden is voor mijn moederbord B460H6-EM en BIOS-versie/datum American Megatrends Inc. 460H6W0X.103, 26-3-2020.
https://community.medion.com/t5/ERAZER-News/Aktuelles-Bios-Update-f%C3%BCr-die-MEDION-ERAZER-Enginee...
ik heb de nieuwe versie gedownload en in eigen map geplaatst maar als ik batch bestand probeer gebeurt er niets.
in command prompt zie ik dit: C:\Users\cmmhl>AFUWINx64.EXE 460H6W0X.107 /P /B /N /REBOOT
'AFUWINx64.EXE' is not recognized as an internal or external command,
operable program or batch file.
en nu snap ik het niet meer. Is er iemand die het nog wel snapt?
40 REPLIES 40
toelis
Message 21 of 41
Message 21 of 41
@daddle
I accidentally marked that as fixed, was wrong button, sorry. my pc came with W10, I updated my pc to W11 with Windows Update.
So the first picture indicated that it was a:
MD34731
MSN: 10023548
Model name: MT28G
Type name: MED MT8277N
plus
NVIDIA GeForce GTX 1650 SUPER
Intel i5-10400F @ 2.90 GHz
thnx, have a nice day
Message 22 of 41
Message 22 of 41
@toelis
Well, that isn't anything serious. As soon as we get a solution you can still mark some more posts as part of a solution.
How did you decompress the zip?
With Windows Explorer, or with eg TotalCommander ? I prefer TotalCommander, because there are two windows parallel open, en copying, comparing or decompressing is more easy and there is more overview.
Decompressing a zip is with Totalcommander very easy You open a zip in on one side, and copying the opened files to the other side automatically decompress them.
I wonder, because after starting the WinFlash.bat and trying to load the  AFUWINx64.EXE comes the break. It looks as if the AFUWINx64.EXE isn't found.
Are you sure your map 460H6W0X.107 contains the decompressed files:
460H6W0X.107
FlashALL_W.bat
flashSYS_W.bat
Idrvdll32e.dll
Pmxdll32e.dll
AfuEfix64.efi
Fpt.efi
AFUWINx64.EXE
FPTW64.exe
flashALL.nsh
flashSYS.nsh
460H6W0X.rom
amifldrv32.sys
amifldrv64.sys
ReleaseNote.txt
toelis
Message 23 of 41
Message 23 of 41
@daddle
it looks like it (15 files both of us)
Maverick
Message 24 of 41
Message 24 of 41
@toelis
Wij hebben namens Medion contact opgenomen met de klant.
met vriendelijke groet,
Maverick
toelis
Message 25 of 41
Message 25 of 41
@Maverick
goedemorgen,
bedoel je dat je contact heb opgenomen of neemt met mij?
fijne dag
toelis
Message 26 of 41
Message 26 of 41
@toelis
dit verbaasd mij ook.  Heb jij geen PN of PM "Private Mail " gekregen?  Hijj schrijft aan jouw hij heeft namens Medion contact met de klant opgenomen? Maar jij bent de klant, en weet er niks van?
@Maverick
Ik vind het uitzettend aardig dat iemand  de zaak nu oppakt. Maar waarom nu zulke geheime diplomatie? Ik heb de laatste 25 posts met veel moeite en betrokkenheit probeert zamen met @toelis  het probleem, waarom de biosupdate niet doorloopt, optelossen.
Maar nu mogen noch ik, noch de gemeenschap weten wat het probleem is ?
Dit doet me denken aan een even vreemd voorval van een paar maanden geleden, toen de bios update voor hetzelfde moederbord  in een andere Medion-computer ook niet kon worden geïnstalleerd, ondanks dat de BIOS-update correct werd uitgevoerd.
Er was toen ook geen openbaar gepubliceerde oplossing, de andere gebruiker viel plotseling stil zonder verder commentaar.
Ik vind deze aanpak vrij  onbeleefd, want als er toen een oplossing was gepubliceerd (als  die er was via PM), hadden we hier nu veel papierwerk en moeite kunnen besparen. En waarom mag dit de community niet te weten krijgen?
Met vriendelijke groet, daddle
toelis
Message 27 of 41
Message 27 of 41
@daddle
ik weet ook niet wat er aan de hand is.
ik heb van niemand (behalve van jou, thnx) iets gehoord.
ondertussen staat dit topic op “solved”, snap er niets van.
groet
toelis
Raichu
Message 28 of 41
Message 28 of 41
@daddle , er is geen geheimzinnig gedoe, we hebben om informatie gevraagd om het probleem op te lossen. Zodra we een oplossing hebben, zullen we die ook posten.
@toelis , als het goed is heb je een privé bericht van @Maverick ontvangen, mocht dat niet het geval zijn, dan zal ik er voor zorgen dat je dat alsnog ontvangt. Het topic staat als opgelost omdat je bij een van de post op "Als oplossing accepteren" hebt geklikt, omdat je hebt aangegeven dat dit per ongeluk is gegaan, volgen we het topic als nog op. Ik zal er voor zorgen dat er morgen als nog contact met je opgenomen wordt. Als je wilt, dan kun je mij ook in een privé bericht je klantgegevens sturen en telefoonnummer, dan ga ik kijken of we telefonisch contact met je op kunnen nemen.
Message 29 of 41
Message 29 of 41
@Raichu
Ok, maar de gegevens staan allemaal hier in de thread. En  ik hab ook niet van  vreemdzinnig gedoe gesproken, maar van "geheime Diplomatie". Een prive les dus.
Ik had MajorTOM nog een keer aangesproken nadat die oplossing per ongeluk aangevinkt was.
Dus ben ik wel benieuwd welke oplossing voor het problem komt opdagen.
Of blijfft dit prive ? Ik heb redenen voor mijn interesse.  Ik heb in mijn PC de zelfde moederbord zitten, die af en toe vreemde verschijningen toont. Daarom vraag ik me af of er iets met de nieuwste biosupdate versie 107 mis is.
Tot ziens, daddle
Raichu
Message 30 of 41
Message 30 of 41
@daddle ,
We gaan (zodra we de gegevens hebben) telefonisch contact opnemen met Toelis, om te kijken of het probleem opgelost kan worden.
Zoals aangegeven, mochten we het probleem op kunnen lossen, dan zullen we de oplossing hier vermelden.
40 REPLIES 40
