What drive caddy can i use to insert SSD drives in my Medion Erazer
4 RÉPONSES 4
bikerwales
Message 1 sur 5
143 Visites
Message 1 sur 5
143 Visites
Hi
I want to add two SSD drives  but I am not sure what type of caddy I need to insert to hold them - there seems to be a spring mounted holder  (see diagram below borrowed from another post!) any ideas please?
1 SOLUTION APPROUVÉE
Solutions acceptées
Message 4 sur 5
126 Visites
Message 4 sur 5
126 Visites
Hello @bikerwales ,
press the two brackets on the slide towards each other
This releases the locking lugs and the slider can be easily pulled out.
bye Fishtown
4 RÉPONSES 4
Message 2 sur 5
141 Visites
Message 2 sur 5
141 Visites
Hello @bikerwales
You can remove the sled and screw the hard drives into the sled. see also here.
https://www.in-win.com/en/gaming-chassis/301#product_download
https://www.in-win.com/uploads/Product/gaming-chassis/301/user-manual/um_301_en.pdf
 Electrical connections from the power grid should be available.
If none was included in the accessories, a SATA data cable must be purchased
which is connected to the circuit board.
Please state the MSn number of the computer
bye Fishtown
bikerwales
Message 3 sur 5
135 Visites
Message 3 sur 5
135 Visites
Hi @Fishtown the MSN number is 10025109. I was having a look in there but wasn't sure how to get the sled out does it just pull out or doies it need major surgery :):):)
Message 4 sur 5
127 Visites
Message 4 sur 5
127 Visites
Hello @bikerwales ,
bye Fishtown
bikerwales
Message 5 sur 5
81 Visites
Message 5 sur 5
81 Visites
@Fishtown Brillaint - many thanks !!!
4 RÉPONSES 4
