Upgrade of Medion Akoya p5360e with graphic card possible?
16 RÉPONSES 16
cojes
Message 1 sur 17
17 025 Visites
Message 1 sur 17
17 025 Visites
Hello everybody,
with which graphic cards I can upgrade my Medion Akoya p5360e. I have already tried four different allegedly compatible graphic cards from AMD and Nvidia, but always beeps the motherboard 5 times.
-The board is a MEDION H110H4-EM with BIOS UEFI 110EMW0X.103 (Chipset: Intel H110 (Skylake PCH-H).
-Built-in original card is a RX 460 2GB, Video BIOS version: 015.050.000.000.016258.
Although it worked with a GTX 1050Ti to start, so I had a picture, but it also beeped always 5 times and the card had always picture dropouts.
Is the board absolutely incompatible for other graphics cards?
Thanks and regards
16 RÉPONSES 16
Bodgekin
Message 2 sur 17
12 856 Visites
Message 2 sur 17
12 856 Visites
Hi @cojes
I dont have experience with this specific board, but I cant imagine it being a compatibility issue with the  motherboard, assuming all cards you tried are UEFI compatible. Is your powersupply sufficient for the new cards? I think the 1050TI needs a 6 pin powerconnection?
And have you tried a different screen and cable combination, just to make sure they're not the problem?
Kind regards,
Bart
cojes
Message 3 sur 17
12 849 Visites
Message 3 sur 17
12 849 Visites
Hi Bart,
the original card AMD RX 460 needs 75W and works fine. I have tried with Nvidia and AMD cards with the same or lower power. The 1050 Ti was connected with the 6 pin powerconnection from the power supply, but the card needs also only 75W. Its a power supply with 350W.
OK, some of the tested older small cards are not UEFI cards, but the GTX 1050 and the GTX 560 are definitely UEFI with low power. The mainboard UEFI is upgradet with the actual version.  Maybe it' a Nvidia/AMD problem?
Regards
Cojes
Bodgekin
Message 4 sur 17
12 844 Visites
Message 4 sur 17
12 844 Visites
Hi @cojes
I don't think AMD or Nvidia should matter, I've exchanged Nvidia and ATI cards on a few systems before, both AMD and Intel based, never had any problems with it. My bet would be a problem with either the screen or the cable, or perhaps the BIOS is set to the internal GPU instead of the discrete card? What happens when you reinstall the original card?
Kind regards,
Bart
cojes
Message 5 sur 17
12 840 Visites
Message 5 sur 17
12 840 Visites
Hi Bart,
deinstallation of the original card had no effect. New card 1050 in slot, start and again it beeps 5x (the board).
=> original card again in slot, computer starts with automatically installation of the original card and it runs fine again without beeps.
Maybe it is a special setting on Medion mainboard?
Regards
Cojes
Bodgekin
Message 6 sur 17
12 747 Visites
Message 6 sur 17
12 747 Visites
Hi @cojes
I meant what happens if you connect the original card again, does that work?
I dont know of any setting in the BIOS outside of a switch between integrated and discrete graphics on some systems.
Kind regards,
Bart
cojes
Message 7 sur 17
12 730 Visites
Message 7 sur 17
12 730 Visites
yes, the original card work without problems in all settings
kuishi
Message 8 sur 17
11 952 Visites
Message 8 sur 17
11 952 Visites
hi,
Do you have find a solution ?
cojes
Message 9 sur 17
11 945 Visites
Message 9 sur 17
11 945 Visites
Hi,
i have checked it with cards RX 560(4GB) and RX 570(8GB, 6pin extra supply). Both are working without problems.
Regards
kuishi
Message 10 sur 17
11 939 Visites
Message 10 sur 17
11 939 Visites
thanks for your answer.
with rx 570, no problem with dimension in the case ? and about alimentation ?
cordialy
16 RÉPONSES 16
