SSD not recognised
3 REPLIES 3
mikeymike
Message 1 of 4
Message 1 of 4
SSD not recognised
I have a new Crucial MX500 ssd which is a clone of my C: drive - I cannot get my AKOYA E4355 MD8341 to recognise it
If I remove the SATA cable from the WD hard drive on C: and replace it on the SSD, it says it cant detect a boot device
If it attach it to any other SATA cable, it simply is not recognised
If i attach it with the SATA/USB cable used for cloning, Acronis recognises it as a copy of the WD drive, but it doesn't show up in windows as a USB device
If i attach it with the SATA/USB cable to a different laptop, it does appear as a USB device and i can see all the folders i would expect to see on my C:drive - any ideas, otherwise i've got an expensive ssd drive I can't use
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@mikeymike
My first guess is your clone of  drive C: the new Crucial volume is faulty.
How big is your C: drive on the HDD?
If you connect the SSD Clone-Drive internally as a second drive, does it show up in WIndows disk management?
Second, why do you clone with a USB Adapter? I know it should work, but more safe would be to clone again, the new SSD connected inside your PC with a second SATA cable.
Make use of AOMEI Backupper or Macrium Reflect free, they may be ore trustworthy.
Regards, daddle
1. How do
mikeymike
Message 3 of 4
Message 3 of 4
Daddle
"If you connect the SSD Clone-Drive internally as a second drive, does it show up in WIndows disk management?" --  Nope - that's using three different sata ports and three different cables, all of which are known to be good
"Second, why do you clone with a USB Adapter?"  (a) you get a free Acronis licence with crucial (b) it's always worked for me in the past (c) none of the sata conections are working
Message 4 of 4
Message 4 of 4
@mikeymike
Look, to be persistent about your own findings does not help you. Your Clone does not function. I can't say why, sitting miles away from your PC.
Just redo it the way I suggest, or leave it. As you like.
3 REPLIES 3
