Power supply for PC Medion Akoya P5319 H / B495 ES
4 ANTWOORDEN 4
manuelonate
Bericht 1 van 5
2.827 Weergaven
Bericht 1 van 5
2.827 Weergaven
Hi,
My power supply broke a few days ago. I have tried to replace it with a new one but I have discovered that the new one has a 24 pin connector for the motherboard, while the motherboard has a 14 pin connector.
I have also found a cable from 24 to 14 pins on Amazon, but I am concerned that it might not work if the cable connections are not correct. The cable is available here (sorry this is Amazon Spain):
https://www.amazon.es/Xiton-alimentaci%C3%B3n-Principal-Fuente-Adaptador/dp/B07F89C5HY/ref=b2b_gw_d_...
I know that I can buy a replacement for the original power supply which is the https://www.shop-fsp.de/FSP450-40EMDN/en, but I would prefer to upgrade it with a more powerful power supply since I am considering changing the graphics card.
I would appreciate any advise.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 4 van 5
2.791 Weergaven
Bericht 4 van 5
2.791 Weergaven
Hi @manuelonate ,
unfortunately we can´t provide any experiences about your power supply and in case of preventing further system/hardware damage in the future we´d suggest investing in the FSP part
Cheers
4 ANTWOORDEN 4
mats749
Bericht 2 van 5
2.816 Weergaven
Bericht 2 van 5
2.816 Weergaven
Hi @manuelonate
Welcome to the community! 😊
Can you provide the MSN number of your Akoya?
Thanks
Mats749
manuelonate
Bericht 3 van 5
2.809 Weergaven
Bericht 3 van 5
2.809 Weergaven
Sure. It is MSN: 1002 0136
Bericht 4 van 5
2.792 Weergaven
Bericht 4 van 5
2.792 Weergaven
Hi @manuelonate ,
Cheers
manuelonate
Bericht 5 van 5
2.784 Weergaven
Bericht 5 van 5
2.784 Weergaven
Ok. Understood.
4 ANTWOORDEN 4
