My Medion MD 34220 PC refuses to boot from USB stick
1 ANTWORT 1
driessenm
Nachricht 1 von 2
4.137 Aufrufe
Nachricht 1 von 2
4.137 Aufrufe
Hello,
I recently bought a Medion MD 34220 PC with Windows 10 Home 64-bit pre-installed on it.
To use certain software tools I absolutely need Windows 10 32 bit.
From the Microsoft website I have created a bootable USB stick with the installation files of Windows 10 32-bit.
However, my Medion MD 34220 PC refuses to boot from this USB.
I have also tried the same thing with a bootable DVD, but that does not work either.
However, if I make a bootable USB stick with the installation files of Windows 10 64-bit, the PC will boot from this USB stick.
How can I make sure that my PC starts from the USB stick with the files of Windows 10 32-bit.
Thank you in advance for hopefully a solution offered.
Regards,
Michel Driessen - Genk (Belgium)
1 ANTWORT 1
Gehringer
Retired
Nachricht 2 von 2
4.098 Aufrufe
Nachricht 2 von 2
4.098 Aufrufe
Hi @driessenm ,
it looks like there is not an official automated solution for your issue.
I suggest you to contact Microsoft to get an official recommendation.
Else, you can acquire and install a 32-bits version of the Windows in your machine
Or you can try one of the solutions proposed on Internet forums (like this one, for instance), even though Medion can not be held responsible for any issues you may have due to that.
Regards,
Gehringer
1 ANTWORT 1
