op 20.04.2020 13:35
op 20.04.2020 13:35
Hi
Spec....
Motherboard MS-7616
Intel Core i3-530 (2.93Ghz 4 mb Intel Smart Cache)
Nvidia Geforce G210 Directx 10 Graphics card with 512mb
3 GB DDR3 SDRAM
1 TB S-ATA disk
Multiformat DVD/CD burner
High Speed Wireless Lan 802.11n-Standard
This desktop is quite old but still works okay. However, on trying to increase RAM to 8GB (2 x 4GB), on startup it immediately goes to "Blue Screen". When I switch off and put the original 3GB RAM back in, it starts up as normal, no Blue Screen. I have reset the BIOS and tried with only 4GB stick. No difference. Help.
22.04.2020 12:29 - bewerkt 22.04.2020 12:30
op 23.04.2020 08:42
op 23.04.2020 08:42
I presume you mean the S/N. Yes, it's on a label at the bottom of the back panel. Should I disclose this number?
op 23.04.2020 08:59
op 23.04.2020 08:59
I also have a Art,-Nr which is 8 digits. The MED S/N is considerably more than 8 digits, though.
op 23.04.2020 09:02
op 23.04.2020 09:02
Okay, just found out that the Art Nr is the MSN and yes it is 8 digits. Is it safe to broadcast this number on this forum?
op 26.04.2020 11:51
op 26.04.2020 11:51
Hi
Yes I have found the MSN. What do I do now?
op 26.04.2020 12:09
op 26.04.2020 12:09
Hi @WalFin
op 26.04.2020 19:42
op 26.04.2020 23:24
op 26.04.2020 23:24
Hi @WalFin
you have:
1x 1024 MB DDR3-SDRAM (PC3-10600 / 1333 MHz)
1x 2048 MB DDR3-SDRAM (PC3-10600 / 1333 MHz)
Memory Support
bye Fishtown
27.04.2020 09:10 - bewerkt 27.04.2020 09:19
Forgive my ignorance in these matters, please see the last RAM I purchased (see photo). Is this one compatible with my MS-7616. I have tried two other RAM cards which were returned (with exactly the same "blue screen" error). Three faulty RAMs is surely almost impossible? Not sure the jpg is showing for some reason. So the RAM is PATRIOT, PSD34G133381, PS00 1042, 4GB PC3-10600 CL9 (4GB PC3-10600 1333MHz CL9). Hope this helps?RAM
