Medion i3-530
15 ANTWORTEN 15
WalFin
Nachricht 1 von 16
17.510 Aufrufe
Nachricht 1 von 16
17.510 Aufrufe
Medion i3-530
Hi
Spec....
Motherboard MS-7616
Intel Core i3-530 (2.93Ghz 4 mb Intel Smart Cache)
Nvidia Geforce G210 Directx 10 Graphics card with 512mb
3 GB DDR3 SDRAM
1 TB S-ATA disk
Multiformat DVD/CD burner
High Speed Wireless Lan 802.11n-Standard
This desktop is quite old but still works okay. However, on trying to increase RAM to 8GB (2 x 4GB), on startup it immediately goes to "Blue Screen". When I switch off and put the original 3GB RAM back in, it starts up as normal, no Blue Screen. I have reset the BIOS and tried with only 4GB stick. No difference. Help.
15 ANTWORTEN 15
Gehringer
Retired
Nachricht 2 von 16
12.075 Aufrufe
Nachricht 2 von 16
12.075 Aufrufe
Hi @WalFin ,
do you have the MSN number of your product?
it is an 8-digits number written in the label underneath it.
Regards,
Gehringer
WalFin
Nachricht 3 von 16
12.070 Aufrufe
Nachricht 3 von 16
12.070 Aufrufe
I presume you mean the S/N. Yes, it's on a label at the bottom of the back panel. Should I disclose this number?
WalFin
Nachricht 4 von 16
12.068 Aufrufe
Nachricht 4 von 16
12.068 Aufrufe
I also have a Art,-Nr which is 8 digits. The MED S/N is considerably more than 8 digits, though.
WalFin
Nachricht 5 von 16
12.066 Aufrufe
Nachricht 5 von 16
12.066 Aufrufe
Okay, just found out that the Art Nr is the MSN and yes it is 8 digits. Is it safe to broadcast this number on this forum?
WalFin
Nachricht 6 von 16
12.045 Aufrufe
Nachricht 6 von 16
12.045 Aufrufe
Hi
Yes I have found the MSN. What do I do now?
Nachricht 7 von 16
12.042 Aufrufe
Nachricht 7 von 16
12.042 Aufrufe
Hi @WalFin
Let us know the number so that we can check which computer you have.
bye Fishtown
WalFin
Nachricht 8 von 16
12.036 Aufrufe
Nachricht 8 von 16
12.036 Aufrufe
MSN 10013506
Nachricht 9 von 16
12.031 Aufrufe
Nachricht 9 von 16
12.031 Aufrufe
Hi @WalFin
you have:
1x 1024 MB DDR3-SDRAM (PC3-10600 / 1333 MHz)
1x 2048 MB DDR3-SDRAM (PC3-10600 / 1333 MHz)
Memory Support
  • DDRIII 1066 / 1333 Mhz (16 GB Max)
  • 4 DDRIII DIMMs (240pin / 1.5V)
  • Single /Dual channel mode
Allocation of the working memory from the service manual from MS 7616 v1.0
bye Fishtown
WalFin
Nachricht 10 von 16
12.014 Aufrufe
Nachricht 10 von 16
12.014 Aufrufe
Forgive my ignorance in these matters, please see the last RAM I purchased (see photo). Is this one compatible with my MS-7616. I have tried two other RAM cards which were returned (with exactly the same "blue screen" error). Three faulty RAMs is surely almost impossible? Not sure the jpg is showing for some reason. So the RAM is PATRIOT, PSD34G133381, PS00 1042, 4GB PC3-10600 CL9 (4GB PC3-10600 1333MHz CL9). Hope this helps?RAMRAM
15 ANTWORTEN 15
