Medion erazer engineer p10 MD35301
1 REPLY 1
Bluesycord
Message 1 of 2
Message 1 of 2
Hi,
Is the Corsair vengeance RGB pro compatible with this models motherboard and if so, can I change the RGB on it? And also, is the Corsair iCUE H100 RGB Elite capellix CPU liquid cooler also compatible? And last but not least, can I put RGB fans into the case and connect it to the motherboard?
Thank you so much,
bluesycord
1 REPLY 1
Mastermind
Message 2 of 2
Message 2 of 2
Hi Bluesycord,
unfortunately we can´t recomment both mentioned compopnents, so that there´s no influence on the prekonfigurated lighting scheme
Cheers
Major Tom
1 REPLY 1
