Medion HDDrive 2 Go Ultra Speed Hard Disk - Replacement AC Adapter in the UK? (KTEC KSAD1200150W1UK)
3 REPLIES 3
zabius
Message 1 of 4
Message 1 of 4
Hi guys,
I used to own a Medion PC years ago but have still got my old drive which I'd like to still check it works and what data is still on the drive but I can no longer find the original adapter. I did have a replacement adapter years ago but even then I recall it didn't work unless I had another add-on pin that connected between the male jack and the female connector on the hard drive itself, can anyone recommend where to get to both the adapter & this small jack adapter?
Also - can someone give me the english version for this Medion manual
http://download2.medion.com/downloads/anleitungen/bda90118de_s.pdf
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hi @zabius and welcome
http://www1.medion.de/downloads/download.pl?id=8189&type=anleitungen&filename=bda90118en.pdf&lang=uk
bye Fishtown
edit:https://www.amazon.de/Netzteil-Steckernetzteil-passend-KSAD1200150W1EU-geeignet/dp/B00F91OU74
or remove the hard drive from the housing and simply connect it to the pc.
zabius
Message 3 of 4
Message 3 of 4
Thanks for that - I am tempted to take the drive apart like in the photo now - can anyone recommend the best way to take this apart safely without damaging the drive inside?
Message 4 of 4
Message 4 of 4
Hi @zabius
it`s very simple, see here:
https://www.youtube.com/watch?v=l4M-EQFfCxM
bye Fishtown
3 REPLIES 3
