Medion Akoya T80 SFF MD35422 Windows 11 Install problem
3 ANTWOORDEN 3
gimmacks
Bericht 1 van 4
2.171 Weergaven
Bericht 1 van 4
2.171 Weergaven
Hello
I have just bought a Medion Akoya T80 SFF MD35422. I'm trying to install windows 11 but it says that I have to install Driver to show hardware. I have downloaded the drivers pack from the support page (drv_t80_m12_w1x.zip) but I cannot find the right driver.
which must I use to install windows 11?
Thank you very much for your help.
Best regards.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
gimmacks
Bericht 4 van 4
2.108 Weergaven
Bericht 4 van 4
2.108 Weergaven
Hello
Problem solved.
The solution was creating de usb install tool in and old pendrive and plug it in the usb 2.0 port in the back (black ones) of the computer.
Best regards.
3 ANTWOORDEN 3
Bericht 2 van 4
2.164 Weergaven
Bericht 2 van 4
2.164 Weergaven
@gimmacks
I guess it is  Intels RST driver, or the isolated VDM driver, to enable the bios to initiate the PCIe disk. Probably you have to put a link to  the driver; you can put them on the Win11 USB Installation stick, if you do use one,  or a single empty USB stick, which has to be inserted in an USB port before you switch the PC on.
Success, daddle
gimmacks
Bericht 3 van 4
2.161 Weergaven
Bericht 3 van 4
2.161 Weergaven
Hello
Thank you very much for your quick answer.
Where can I get this driver? Is not in the driver package I downloaded from medion support site?
Best regards.
gimmacks
Bericht 4 van 4
2.109 Weergaven
Bericht 4 van 4
2.109 Weergaven
Hello
Problem solved.
Best regards.
3 ANTWOORDEN 3
